P568-050
P568-050
    TRIPPLITE
    P568-050
P568-050 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States In some applications, a signal booster (Model Number: B122-000-60) should be used with this cable to ensure a signal strong enough for your display. An alternate solution is to use a Tripp Lite HDMI over Cat5 Highlights ● Premium double-shielded digital audio/video cable ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Bandwidth up to 10.2 Gbps Full 1080p resolution ● Standard Speed HDMI and HDCP compliant ● Supports HD Video resolutions up to 1080p Extender (Model Number: B126-1A1) in place of a 50 ft. HDMI cable and signal booster. Standard-Speed HDMI Cable, Digital Video with Audio (M/M), Black, 50 ft. (15.24 m) MODEL NUMBER: P568-050 Package Includes ● Features ● Creates a pure digital connection between HDMI-enabled HDTV display devices and HDMI-enabled digital video sources ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Premium double-shielded cable protects against outside noise (EMI/RFI) ● Impedance-matched twisted-pair construction reduces cross-talk and interference ● Bandwidth up to 10.2 Gbps - Full 1080p resolution ● In most applications, a signal booster (B122-000-60) will need to be used with this cable to ensure a signal strong enough for your display Specifications OVERVIEW UPC Code 037332137852 Product Type Passive Cable Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 (4K) @ 30Hz 1/3 50-ft. Standard Speed HDMI Gold Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification ARC USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 7.3 mm Wire Gauge (AWG) 28 Cable Length (ft.) 50 Cable Length (m) 15.24 Cable Length (in.) 600 Ferrite Core No Minimum Bend Radius 36.5mm Shipping Dimensions (hwd / in.) 10.00 x 12.00 x 1.00 Shipping Dimensions (hwd / cm) 25.40 x 30.48 x 2.54 Shipping Weight (lbs.) 2.20 Shipping Weight (kg) 1.00 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P568-050 价格&库存
很抱歉,暂时无法提供与“P568-050”相匹配的价格&库存,您可以联系我们找货
P568-050
    • 1+602.655271+78.11560
    • 10+512.2724310+66.40026
    • 25+480.2183725+62.24545
    • 50+457.3198350+59.27736
    • 100+447.78409100+58.04135
    库存:10
