P568-010
P568-010
    TRIPPLITE
    P568-010
P568-010 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High-Speed HDMI Cable, Digital Video with Audio, UHD 4K (M/M), Black, 10 ft. (3.05 m) MODEL NUMBER: P568-010 Highlights ● Premium double-shielded digital audio/video cable ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● High Speed HDMI and HDCP compliant ● Supports Ultra High Definition (UHD) 4K video resolutions Package Includes ● Description Tripp Lite's 10-ft. (3.05 m) High Speed HDMI (High-Definition Multimedia Interface) Gold Cable allows interconnection between digital display devices, such as DTV's (Digital Television), Plasma displays, LCD TV's and projectors, to Digital source devices, such as Digital Set-Top boxes, Blu-Ray players and AV receivers. Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter. HDMI assures that the best audio/video signal is always sent from the source (HDTV signal, Blu-Ray Player) to the display (Projection Television, LCD, Plasma, etc.). It does this by allowing uncompressed video and multi-channel audio data to be input to the display device through one single cable. An HDMI connection allows input at high rates of speed, up to 18 Gbps. Features ● Creates a pure digital connection between HDMI-enabled HDTV display devices and HDMI-enabled digital video sources ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Premium double-shielded cable protects against outside noise (EMI/RFI) ● Impedance-matched twisted-pair construction reduces cross-talk and interference ● Perfect for connecting an iPad2 to an HDTV (video mirroring) to watch movies, play games, surf the web and display presentations ● Supports Ultra High Definition (UHD) 4K video resolutions Specifications OVERVIEW UPC Code 037332122926 Product Type Passive Cable Technology HDMI 1/3 10-ft. (3.05 m) High Speed HDMI Gold Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 (4K) @ 30Hz Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported No Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification Stereo Audio USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.5 mm Wire Gauge (AWG) 30 Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Ferrite Core No Minimum Bend Radius 55mm Shipping Dimensions (hwd / in.) 9.10 x 6.90 x 0.10 Shipping Dimensions (hwd / cm) 23.11 x 17.53 x 0.25 Shipping Weight (lbs.) 0.33 Shipping Weight (kg) 0.15 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Temperature Range -40° to 176°F (-40° to 80°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.3 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P568-010
物料型号: - MODEL NUMBER: P568-010
器件简介: - Tripp Lite P568-010是一款高速HDMI线缆,支持数字视频与音频传输,兼容UHD 4K分辨率,长度为10英尺(3.05米),黑色。
引脚分配: - Side A - Connector 1: HDMI (MALE) - Side B - Connector 1: HDMI (MALE)
参数特性: - 技术:HDMI - 电缆类型:被动(Passive) - 最大支持视频分辨率:3840x2160(4K)@ 30Hz - 最大支持色深:24-bit True Color - HDR支持:不支持 - 3D视频支持:不支持 - 色度子采样:4:4:4 - EDID支持:是 - 信号传输:双向 - 音频规格:立体声音频 - 连接器镀层:金 - 接触镀层:金 - 连接器样式:直头 - 连接器颜色:黑色 - 线缆外径(OD):5.5mm - 线规(AWG):30 - 线缆长度:10英尺(3.05米) - 最小弯曲半径:55mm - 运输尺寸:9.10x6.90x0.10英寸
功能详解: - 该线缆支持iPad2视频镜像功能,需配合苹果数字AV适配器使用。 - 金镀连接器提供最优化的信号传输。 - 高速HDMI且符合HDCP规范。 - 支持超高清(UHD)4K视频分辨率。 - 适用于连接HDMI兼容的高清电视显示设备和数字视频源,包括卫星/有线电视盒、蓝光播放器和AV接收器。
应用信息: - 适用于连接iPad2至HDTV(视频镜像),观看电影、玩游戏、上网冲浪等。 - 适用于商务演示和家庭娱乐。
封装信息: - 颜色:黑色 - 线缆外套材料:PVC - 线缆外套等级:VW-1 - 包装包含:10英尺(3.05米)高速HDMI金线缆一根。
P568-010 价格&库存
很抱歉,暂时无法提供与“P568-010”相匹配的价格&库存,您可以联系我们找货
