P583-010
P583-010
    TRIPPLITE
    P583-010
P583-010 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mini DisplayPort to DisplayPort Adapter Cable, 4K 60Hz (M/M), DP Latching Connector, White, 10 ft. (3.1 m) Highlights ● Supports UHD video resolutions up to 4096 x 2160 (4K x 2K) @ 60 Hz ● Locking DisplayPort connector prevents accidental disconnection ● Gold-plated connectors and contacts for maximum conductivity ● Meets DisplayPort 1.2 standards ● Supports High Bit Rate 2 (HBR2) bandwidth up to 21.6 Gbps MODEL NUMBER: P583-010 System Requirements ● Source device with Mini DisplayPort, Thunderbolt or DisplayPort output ● Display device with DisplayPort, mDP or Thunderbolt input Package Includes Allows connection of a DisplayPort device to a device with Mini DisplayPort (mDP) or Thunderbolt ports. Features Sends Ultra High Definition Mini DisplayPort Audio/Video to DisplayPort Monitor or DisplayPort Audio/Video to Mini DisplayPort Monitor ● Connects mDP or Thunderbolt computer or laptop to DisplayPort monitor, TV or projector or connects the DisplayPort output on your computer or laptop to the Mini DisplayPort (mDP) or Thunderbolt input on your monitor, television or projector ● Recommended for displaying video on large monitor or digital sign ● No separate power adapter required Vibrant Video Quality ● Supports UHD video resolutions up to 4096 x 2160 (4K x 2K) @ 60 Hz ● Meets DisplayPort 1.2 standards ● Supports High Bit Rate 2 (HBR2) bandwidth up to 21.6 Gbps ● Backward compatible with previous DisplayPort versions Superior Materials for Superior Performance ● Locking DisplayPort connector prevents accidental disconnection ● Gold-plated connectors and contacts for maximum conductivity and minimum data loss ● Integral strain relief reduces stress and adds flexibility Specifications OVERVIEW UPC Code 037332174604 Product Type Passive Cable 1/3 P583-010 Mini DisplayPort to DisplayPort 4K @60Hz Adapter (M/M), 10 ft. (3.1 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology DisplayPort Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 (4K) @ 60Hz Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:2:0; 4:2:2 Signal Transmission Bidirectional PHYSICAL Color White Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.8 mm Wire Gauge (AWG) 32 Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Ferrite Core No Minimum Bend Radius 48mm Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.37 Shipping Weight (kg) 0.17 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range -40° to 158°F (-40° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Consumer Electronics Control (CEC) Supported No CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 MINI DISPLAYPORT (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector Yes FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support Yes Antibacterial No IP68 Rated No Armored Cable No Ethernet Support No Displayport Specification 1.2 HDCP Specification 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P583-010
1. 物料型号: - 型号编号:P583-010 - UPC代码:037332174604 - 产品类型:被动线缆(Passive Cable) - 技术:DisplayPort
2. 器件简介: - 该产品为Mini DisplayPort至DisplayPort适配器线缆,支持4K 60Hz视频传输,长度为10英尺(3.1米),白色,具有DP锁定连接器,防止意外断开。
3. 引脚分配: - 侧A - 连接器1:DISPLAYPORT(公头) - 侧B - 连接器1:MIN DISPLAYPORT(公头)
4. 参数特性: - 最大支持视频分辨率:3840x2160(4K)@60Hz - 最大支持颜色深度:24位真彩色 - HDR支持:否 - 3D视频支持:是 - 色度子采样:4:2:0, 4:2:2 - 信号传输:双向 - 连接器镀层:金 - 接触镀层:金 - 连接器样式:直头 - 是否有锁定或抓握连接器:是 - 颜色:白色 - 线缆外径(OD):4.8mm - 线规(AWG):32 - 线缆长度:10英尺(3.05米,120英寸) - 是否有铁氧体芯:否 - 最小弯曲半径:48mm
5. 功能详解: - 支持超高清Mini DisplayPort音视频传输至DisplayPort监视器或DisplayPort音视频传输至Mini DisplayPort监视器。 - 连接mDP或Thunderbolt电脑或笔记本至DisplayPort监视器、电视或投影仪,或将电脑或笔记本上的DisplayPort输出连接至监视器、电视或投影仪上的Mini DisplayPort(mDP)或Thunderbolt输入。 - 推荐用于在大屏幕上显示视频或数字标牌。 - 不需要单独的电源适配器。 - 支持UHD视频分辨率高达4096 x 2160(4K x 2K)@ 60Hz。 - 符合DisplayPort 1.2标准。 - 支持高比特率2(HBR2)带宽高达21.6 Gbps。 - 向后兼容以前的DisplayPort版本。
6. 应用信息: - 用于连接DisplayPort设备至具有Mini DisplayPort(mDP)或Thunderbolt端口的设备。
7. 封装信息: - 线缆外套颜色:白色 - 线缆外套材料:PVC - 线缆外套等级:VW-1 - 发货尺寸(高宽深/英寸):9.00x7.00x0.50 - 发货尺寸(高宽深/厘米):22.86x17.78x1.27 - 发货重量(磅):0.37 - 发货重量(千克):0.17
P583-010 价格&库存
很抱歉,暂时无法提供与“P583-010”相匹配的价格&库存,您可以联系我们找货
