P568-006-RA2
P568-006-RA2
    TRIPPLITE
    P568-006-RA2
P568-006-RA2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High-Speed HDMI Cable with 2 Right-Angle Connectors, Digital Video with Audio (M/M), 6 ft. (1.83 m) Highlights ● Features right-angle connectors on both ends; ideal for tight locations ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Bandwidth up to 18 Gbps - Full 1080p resolution ● High Speed HDMI and HDCP compliant MODEL NUMBER: P568-006-RA2 Package Includes ● Features ● Features right-angle connectors on both ends; ideal for tight locations ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Premium double-shielded cable protects against outside noise (EMI/RFI) ● Impedance-matched twisted-pair construction reduces cross-talk and interference ● Bandwidth up to 18 Gbps - Full 1080p resolution ● Perfect for connecting an iPad2 to an HDTV (video mirroring) to watch movies, play games, surf the web and display presentations Specifications OVERVIEW UPC Code 037332146090 Product Type Passive Cable Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 1920 x 1200 (1080p) Max Supported Color Depth 48-bit Deep Color HDR Support No 1/3 6-ft. High Speed HDMI Gold Cable with Right-Angle Connectors 1000 Eaton Boulevard Cleveland, OH 44122 United States 3D Video Supported No Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification DTS-HD USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.5 mm Wire Gauge (AWG) 30 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Ferrite Core No Minimum Bend Radius 27.5mm Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Angled Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P568-006-RA2 价格&库存
很抱歉,暂时无法提供与“P568-006-RA2”相匹配的价格&库存,您可以联系我们找货
P568-006-RA2
    • 1+202.416181+26.26333
