P568-006-WH
P568-006-WH
    TRIPPLITE
    HDMI CABLE CONN 6'
P568-006-WH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High-Speed HDMI Cable (M/M) - 4K, Gripping Connectors, White, 6 ft. (1.8 m) MODEL NUMBER: P568-006-WH Highlights ● Supports UHD video resolutions up to 4K ● Backward compatible with previous HDMI generations ● Premium foil and braid shielding protects against EMI/RFI noise ● Gold-plated white connectors for optimal signal transfer Package Includes P568-006-WH High-Speed HDMI Cable (M/M), White, 6 ft. (1.8 m) Connects two 4K-enabled devices, including computers, Blu-ray players, video game systems, DVRs, video cameras, A/V receivers, monitors, projectors and televisions. Description The P568-006-WH High-Speed HDMI 4K Cable (M/M) is recommended for digital signage, video presentations, point-of-sale displays, classrooms and other applications that display Ultra High Resolution (UHD) video and multi-channel audio. It connects 4K-enabled source devices, such as computers and Blu-ray players, to 4K-enabled displays, such as monitors, projectors and televisions. This cable supports video resolutions up to Ultra HD 4K x 2K (4096 x 2160) at 30 Hz. When used with an Apple digital AV adapter, it supports iPad2 video mirroring for playing games, watching videos or displaying presentations. The six-foot (1.8-meter) molded 30 AWG cable features premium foil and braid shielding to deliver reliable, error-free signal quality and protection from EMI/RFI line noise that can distort or destroy data. Gold-plated white connectors provide maximum conductivity and minimize data loss. Integral strain relief gives the cable extra flexibility, reduces stress, and helps the cable and connectors move freely without cracking. A flexible PVC jacket makes the HDCP pass-through cable easy to install in tight spaces. Features Connects HDMI Source to 4K TV, Projector or Monitor ● Ideal for digital signage, video presentations, point-of-sale displays, classrooms and other applications with 4K video and multi-channel audio High Performance and Wide Compatibility ● Supports UHD video resolutions up to 4K ● Complies with HDCP pass-through standards ● Supports iPad2 video mirroring when used with Apple digital A/V adapter ● Backward compatible with previous HDMI generations Superior Quality Ensures a Flawless Signal ● Corrosion-resistant gold-plated white connectors for maximum conductivity and minimum data loss ● Fully molded 30 AWG construction with integral strain relief reduces stress and adds flexibility ● Premium foil and braid shielding for EMI/RFI noise protection ● Flexible PVC jacket easy to install in tight spaces 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332184801 Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 @ 30Hz Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported No Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification Stereo Audio USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color White Cable Jacket Color White Connector Color White Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.5 mm Wire Gauge (AWG) 30 Cable Length (ft.) 6 Cable Length (m) 1.83 Ferrite Core No Minimum Bend Radius 55mm Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.24 Shipping Weight (kg) 0.11 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range -40 to 176 F (-40 to 80 C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.3 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P568-006-WH 价格&库存
很抱歉,暂时无法提供与“P568-006-WH”相匹配的价格&库存,您可以联系我们找货
