P568-003-YW
P568-003-YW
    TRIPPLITE
    P568-003-YW
P568-003-YW 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High-Speed HDMI Cable, Digital Video and Audio, UHD 4K (M/M), Yellow, 3 ft. (0.91 m) MODEL NUMBER: P568-003-YW Highlights ● Supports UHD video resolutions up to 4K ● Backward compatible with previous HDMI generations ● Premium foil and braid shielding protects against EMI/RFI noise ● Gold-plated yellow connectors for optimal signal transfer Package Includes ● High-speed premium cable connects two Ultra HD HDMI-enabled devices, including computers, Blu-ray™ players, video game systems, DVRs, video cameras, A/V receivers, monitors, projectors and televisions. Features Connects HDMI Source to 4K TV, Projector or Monitor ● Ideal for digital signage, video presentations, point-of-sale displays, classrooms and other applications that display Ultra High Resolution (UHD) video and multi-channel audio High Performance and Wide Compatibility ● Supports UHD video resolutions up to 4K ● Supports iPad2 video mirroring when used with Apple digital AV adapter ● Backward compatible with previous HDMI generations Superior Quality Ensures a Flawless Signal ● Corrosion-resistant gold-plated yellow connectors for optimal signal transfer ● Fully molded 30 AWG construction with integral strain relief for durability and long life ● Premium foil and braid shielding for EMI/RFI noise protection ● Flexible PVC jacket easy to install in tight spaces Specifications OVERVIEW UPC Code 037332197092 Technology HDMI Cable Type Passive 1/3 P568-003-YW High-Speed HDMI Cable with Digital Video and Audio (M/M), Yellow, 3 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States VIDEO Max Supported Video Resolution 3840 x 2160 @ 30Hz Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification ARC USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Yellow Material of Construction ABS Cable Jacket Color Yellow Connector Color Yellow Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 6.0mm Wire Gauge (AWG) 30 Cable Length (ft.) 3 Cable Length (m) 0.91 Ferrite Core No Minimum Bend Radius 30mm Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P568-003-YW 价格&库存
很抱歉,暂时无法提供与“P568-003-YW”相匹配的价格&库存,您可以联系我们找货
