1000 Eaton Boulevard
Cleveland, OH 44122
United States
High Speed HDMI Cable with Ethernet, UHD 4K,
Digital Video with Audio (M/M), 1 ft. (0.31 m)
MODEL NUMBER: P569-001
Highlights
Supports UHD video resolutions
up to 4K
Backward compatible with
previous HDMI generations
Premium foil and braid shielding
protects against EMI/RFI noise
Gold-plated connectors and
contacts for optimal signal
transfer
Package Includes
Transmits digital audio/video and Ethernet signals from an HDMI source to a 4K-enabled television,
projector or monitor. Ideal for home theater systems, digital signage and other applications that display
UHD video.
Features
Connects HDMI Source to 4K TV, Projector or Monitor
● Ideal for home theater systems, digital signage and other applications that display UHD video and multichannel audio
High Performance and Wide Compatibility
● Supports UHD video resolutions up to 4K, and 3D
Audio return channel simplifies setup between display and receiver
Supports iPad2 video mirroring when used with Apple digital A/V adapter
Backward compatible with previous HDMI generations
Works in all HDMI cabling scenarios
Superior Construction Ensures a Flawless Signal
● Fully molded 30 AWG construction with integral strain relief for durability and long life
Premium foil and braid shielding for EMI/RFI noise protection
Corrosion-resistant gold-plated connectors and contacts for optimal signal transfer
Flexible PVC jacket easy to install in tight spaces
Specifications
OVERVIEW
UPC Code
037332198280
1/4
P569-001 High-Speed HDMI
Cable with Ethernet and Digital
Cleveland, OH 44122
United States
Product Type
Passive Cable
Technology
HDMI
Cable Type
Passive
VIDEO
Max Supported Video Resolution
3840 x 2160 (4K) @ 30Hz
Max Supported Color Depth
48-bit Deep Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
EDID Support
Yes
Signal Transmission
Bidirectional
AUDIO
Audio Specification
ARC
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PHYSICAL
Color
Black
Material of Construction
PVC
Cable Jacket Color
Black
Connector Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
6.0 mm
Wire Gauge (AWG)
30
Cable Length (ft.)
1
Cable Length (m)
0.30
Cable Length (in.)
12
Ferrite Core
No
Cable Length (cm)
30.48
Minimum Bend Radius
30mm
Shipping Dimensions (hwd / in.)
0.50 x 7.00 x 9.75
Shipping Dimensions (hwd / cm)
1.27 x 17.78 x 24.76
Shipping Weight (lbs.)
0.08
2/4
Cleveland, OH 44122
United States
Shipping Weight (kg)
0.04
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Side A - Connector 1
HDMI (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
No
MST Support
No
Antibacterial
No
IP68 Rated
No
IP20 Rated
No
Armored Cable
No
Ethernet Support
Yes
HDCP Specification
1.4; 2.2
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
3/4
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“P569-001”相匹配的价格&库存,您可以联系我们找货
