P568-003-GN
P568-003-GN
    TRIPPLITE
    P568-003-GN
P568-003-GN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High-Speed HDMI Cable, Digital Video with Audio, 4K (M/M), Green Connectors, 3 ft. (0.91 m) MODEL NUMBER: P568-003-GN Highlights ● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) ● Supports data transfer speeds up to 18 Gbps ● Backward compatible with previous HDMI generations ● Premium foil and braid shielding protects against EMI/RFI noise ● Gold-plated green connectors for optimal signal transfer Package Includes ● High-speed premium cable connects two Ultra HD HDMI-enabled devices, including computers, Blu-ray™ players, video game systems, DVRs, video cameras, A/V receivers, monitors, projectors and televisions. Features Connects HDMI Source to 4K TV, Projector or Monitor ● Ideal for digital signage, video presentations, point-of-sale displays, classrooms and other applications that display Ultra High Resolution (UHD) video and multi-channel audio High Performance and Wide Compatibility ● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K), including 1080p ● Supports data transfer speeds up to 18 Gbps—the fastest bandwidth currently available over HDMI ● Supports iPad2 video mirroring when used with Apple digital AV adapter ● Backward compatible with previous HDMI generations Superior Quality Ensures a Flawless Signal ● Corrosion-resistant gold-plated green connectors for optimal signal transfer ● Fully molded 30 AWG construction with integral strain relief for durability and long life ● Premium foil and braid shielding for EMI/RFI noise protection ● Flexible PVC jacket easy to install in tight spaces Specifications OVERVIEW UPC Code 037332197085 Technology HDMI Cable Type Passive 1/3 P568-003-GN High-Speed HDMI Cable with Digital Video and Audio (M/M), Green, 3 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States VIDEO Max Supported Video Resolution 3840 x 2160 @ 30Hz Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional Bandwidth 10.2 Gbps AUDIO Audio Specification ARC USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Green Material of Construction ABS Cable Jacket Color Black Connector Color Green Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 6.0mm Wire Gauge (AWG) 30 Cable Length (ft.) 3 Cable Length (m) 0.91 Ferrite Core No Minimum Bend Radius 30mm Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.4; 2.2 WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P568-003-GN
1. 物料型号: - 型号编号:P568-003-GN
2. 器件简介: - 该产品是一款高速HDMI电缆,支持数字视频和音频,具有4K分辨率,采用绿色连接器,长度为3英尺(0.91米)。
3. 引脚分配: - 两端均为HDMI(公头)连接器。
4. 参数特性: - 最高支持视频分辨率:3840x2160@30Hz - 最高支持颜色深度:48位深颜色 - HDR支持:不支持 - 支持3D视频:是 - 色度子采样:4:4:4 - EDID支持:是 - 信号传输:双向 - 带宽:10.2 Gbps - 音频规格:ARC - 连接器镀金:是 - 接触镀金:是 - 连接器样式:直头 - 锁定或夹紧连接器:无 - 颜色:绿色 - 材料:ABS - 电缆护套颜色:黑色 - 连接器颜色:绿色 - 电缆护套材料:PVC - 电缆护套等级:VW-1 - 电缆外径(OD):6.0mm - 线规(AWG):30 - 电缆长度(英尺):3 - 电缆长度(米):0.91 - 无铁氧体核心 - 最小弯曲半径:30mm
5. 功能详解: - 支持4K超高清(UHD)视频分辨率,包括1080p。 - 支持数据传输速度高达18 Gbps。 - 支持iPad2视频镜像,需配合Apple数字AV适配器使用。 - 向后兼容以前的HDMI版本。
6. 应用信息: - 适用于连接HDMI源到4K电视、投影仪或显示器,显示超高分辨率(UHD)视频和多声道音频。 - 适合数字标牌、视频演示、销售点显示、教室等应用。
7. 封装信息: - 电缆长度:3英尺(0.91米)。 - 电缆外径:6.0mm。 - 线规:30AWG。 - 电缆护套材料:PVC。 - 连接器颜色:绿色。 - 电缆护套颜色:黑色。
P568-003-GN 价格&库存
很抱歉,暂时无法提供与“P568-003-GN”相匹配的价格&库存,您可以联系我们找货
