1000 Eaton Boulevard
Cleveland, OH 44122
United States
High-Speed HDMI Cable, Digital Video and Audio,
UHD 4K (M/M), Red, 6 ft. (1.83 m)
MODEL NUMBER: P568-006-RD
Highlights
Supports UHD video resolutions
up to 4K
Backward compatible with
previous HDMI generations
Premium foil and braid shielding
protects against EMI/RFI noise
Gold-plated red connectors for
optimal signal transfer
Package Includes
High-speed premium cable connects two Ultra HD HDMI-enabled devices, including computers, Blu-ray™
players, video game systems, DVRs, video cameras, A/V receivers, monitors, projectors and televisions.
Features
Connects HDMI Source to 4K TV, Projector or Monitor
● Ideal for digital signage, video presentations, point-of-sale displays, classrooms and other applications
that display Ultra High Resolution (UHD) video and multi-channel audio
High Performance and Wide Compatibility
● Supports UHD video resolutions up to 4K
Supports iPad2 video mirroring when used with Apple digital AV adapter
Backward compatible with previous HDMI generations
Superior Quality Ensures a Flawless Signal
● Corrosion-resistant gold-plated red connectors for optimal signal transfer
Fully molded 30 AWG construction with integral strain relief for durability and long life
Premium foil and braid shielding for EMI/RFI noise protection
Flexible PVC jacket easy to install in tight spaces
Specifications
OVERVIEW
UPC Code
037332197030
Product Type
Passive Cable
Technology
HDMI
1/4
P568-006-RD High-Speed
HDMI Cable with Digital Video
and Audio (M/M), Red, 6 ft.
Cleveland, OH 44122
United States
Cable Type
Passive
VIDEO
Max Supported Video Resolution
3840 x 2160 (4K) @ 30Hz
Max Supported Color Depth
48-bit Deep Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
EDID Support
Yes
Signal Transmission
Bidirectional
AUDIO
Audio Specification
ARC
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PHYSICAL
Color
Red
Material of Construction
ABS
Cable Jacket Color
Red
Connector Color
Red
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
6.0 mm
Wire Gauge (AWG)
30
Cable Length (ft.)
6
Cable Length (m)
1.83
Cable Length (in.)
72
Ferrite Core
No
Minimum Bend Radius
30mm
Shipping Dimensions (hwd / in.)
9.00 x 7.20 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 18.29 x 1.27
Shipping Weight (lbs.)
0.20
Shipping Weight (kg)
0.09
ENVIRONMENTAL
2/4
Cleveland, OH 44122
United States
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Side A - Connector 1
HDMI (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
No
MST Support
No
Antibacterial
No
IP68 Rated
No
IP20 Rated
No
Armored Cable
No
Ethernet Support
No
HDCP Specification
1.4; 2.2
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
3/4
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“P568-006-RD”相匹配的价格&库存,您可以联系我们找货
