P568-010-GN
P568-010-GN
    TRIPPLITE
    P568-010-GN
P568-010-GN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High-Speed HDMI Cable, Digital Video with Audio, UHD 4K (M/M), Green, 10 ft. (3.05 m) MODEL NUMBER: P568-010-GN Highlights ● Supports UHD video resolutions up to 4K ● Backward compatible with previous HDMI generations ● Premium foil and braid shielding protects against EMI/RFI noise ● Gold-plated green connectors for optimal signal transfer Package Includes ● High-speed premium cable connects two Ultra HD HDMI-enabled devices, including computers, Blu-ray™ players, video game systems, DVRs, video cameras, A/V receivers, monitors, projectors and televisions. Description The P568-010-GN High-Speed HDMI Cable is ideal for digital signage, video presentations, point-of-sale displays, classrooms and other applications that display Ultra High Resolution (UHD) video and multichannel audio. It connects HDMI-enabled source devices, such as computers and Blu-ray™ players, to HDMI-enabled displays, such as monitors, projectors and high-definition televisions. This cable supports UHD video resolutions up to 3840 x 2160 (4K x 2K), including full 1080p, and data transfer speeds up to 18 Gbps—the fastest bandwidth currently available over HDMI. When used with an Apple® digital AV adapter, it supports iPad2® video mirroring for playing games, watching videos or displaying presentations. Backward compatible with previous HDMI generations, the P568-010-GN works in all HDMI cabling scenarios. The 10-ft. (3.05 m) molded 30 AWG cable features premium foil and braid shielding to deliver top-of-theline signal quality and protection from EMI/RFI interference. Gold-plated green connectors ensure excellent conductivity. Integral strain relief ensures the cable and connectors last a long time. A flexible PVC jacket makes the HDCP-compliant cable easy to install in tight spaces. Features Connects HDMI Source to 4K TV, Projector or Monitor ● Ideal for digital signage, video presentations, point-of-sale displays, classrooms and other applications that display Ultra High Resolution (UHD) video and multi-channel audio High Performance and Wide Compatibility ● Supports UHD video resolutions up to 4K ● Supports iPad2 video mirroring when used with Apple digital AV adapter ● Backward compatible with previous HDMI generations Superior Quality Ensures a Flawless Signal ● Corrosion-resistant gold-plated green connectors for optimal signal transfer ● Fully molded 30 AWG construction with integral strain relief for durability and long life ● Premium foil and braid shielding for EMI/RFI noise protection 1/4 P568-010-GN High-Speed HDMI Cable with Digital Video and Audio (M/M), Green, 10-ft. (3.05 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Flexible PVC jacket easy to install in tight spaces Specifications OVERVIEW UPC Code 037332197511 Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 @ 30Hz Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional Bandwidth 18 Gbps AUDIO Audio Specification ARC USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Green Material of Construction ABS Cable Jacket Color Green Connector Color Green Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 6.0mm Wire Gauge (AWG) 30 Cable Length (ft.) 10 Cable Length (m) 3.05 Ferrite Core No 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Bend Radius 30mm Shipping Dimensions (hwd / in.) 10.00 x 7.20 x 0.50 Shipping Dimensions (hwd / cm) 25.40 x 18.29 x 1.27 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P568-010-GN 价格&库存
很抱歉,暂时无法提供与“P568-010-GN”相匹配的价格&库存,您可以联系我们找货
