1000 Eaton Boulevard
Cleveland, OH 44122
United States
High-Speed HDMI Cable with Ethernet and Digital
Video with Audio, UHD 4K, In-Wall CL3-Rated
(M/M), 6 ft. (1.83 m)
MODEL NUMBER: P569-006-CL3
Highlights
Supports UHD resolutions up to
4K (4:4:4) for crystal-clear video
Backward compatible with
previous HDMI generations
CL3-rated jacket supports inwall installation
Premium foil and braid shielding
protects against EMI/RFI noise
Package Includes
Transmits digital audio/video and Ethernet signals from an HDMI source to a 4K television, projector or
monitor. Ideal for in-wall home theater systems, digital signage and other applications that display UHD
video.
Features
Connects HDMI Source to 4K TV, Projector or Monitor
● Ideal for home theater systems, digital signage and other applications that display UHD video and multichannel audio
CL3 rating suitable for in-wall installation
High Performance and Wide Compatibility
● Supports UHD and 3D video resolutions up to 4K
Supports iPad2 video mirroring when used with Apple digital A/V adapter
Backward compatible with previous HDMI generations
Works in all HDMI cabling scenarios
Superior Quality Ensures a Flawless Signal
● Fully molded 30 AWG construction with integral strain relief for durability and long life
Premium foil and braid shielding for EMI/RFI noise protection
Corrosion-resistant gold-plated connectors for optimal signal transfer
Flexible PVC jacket easy to install in tight spaces
Specifications
OVERVIEW
1/4
P569-006-CL3 High-Speed
Digital Video with Audio (M/M),
6 ft.
Cleveland, OH 44122
United States
UPC Code
037332197337
Product Type
Passive Cable
Technology
HDMI
Cable Type
Passive
VIDEO
Max Supported Video Resolution
3840 x 2160 (4K) @ 60Hz
Max Supported Color Depth
24-bit True Color
HDR Support
Yes
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
EDID Support
Yes
Signal Transmission
Unidirectional
AUDIO
Audio Specification
TrueHD/DTS-HD Master Audio bitstream
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PHYSICAL
Color
Black
Cable Jacket Color
Black
Connector Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
CL3
Cable Outer Diameter (OD)
6.0 mm
Wire Gauge (AWG)
30
Cable Length (ft.)
6
Cable Length (m)
1.83
Cable Length (in.)
72
Ferrite Core
No
Minimum Bend Radius
60mm
Shipping Dimensions (hwd / in.)
7.00 x 8.50 x 0.50
Shipping Dimensions (hwd / cm)
17.78 x 21.59 x 1.27
Shipping Weight (lbs.)
0.40
Shipping Weight (kg)
0.18
2/4
Cleveland, OH 44122
United States
ENVIRONMENTAL
Operating Temperature Range
32° to 122°F (0° to 50°C)
Storage Temperature Range
14° to 176°F (-10° to 80°C)
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
COMMUNICATIONS
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Side A - Connector 1
HDMI (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
No
MST Support
No
Antibacterial
No
IP68 Rated
No
IP20 Rated
No
Armored Cable
No
Ethernet Support
Yes
Fire Rating
CL3 Rated
HDCP Specification
2.2
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
3/4
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“P569-006-CL3”相匹配的价格&库存,您可以联系我们找货
