P580-001
P580-001
    TRIPPLITE
    P580-001
P580-001 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort Cable with Latching Connectors, 4K 60 Hz (M/M), Black, 1 ft. (0.31 m) MODEL NUMBER: P580-001 Highlights ● Digital Video and Audio in one cable ● Supports 1080p resolution ● Small footprint compared to VGA or DVI ● Supports Ultra High Definition (UHD) 4K x 2K video resolutions up to 3840 x 2160 @ 60Hz Package Includes DisplayPort Monitor Cable - 1-ft. Features ● The future standard for Digital Video and Audio connections ● Supports Displayport v1.2 ● Supports High Definition Content Protection ( HDCP ) ● Supports Ultra High Definition (UHD) 4K x 2K video resolutions up to 3840 x 2160 @ 60Hz Specifications OVERVIEW UPC Code 037332186188 Product Type Passive Cable Technology DisplayPort Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 (4K) @ 60Hz Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:2:0; 4:2:2 Signal Transmission Bidirectional 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 6.0 mm Wire Gauge (AWG) 30 Cable Length (ft.) 1 Cable Length (m) 0.30 Cable Length (in.) 12 Ferrite Core No Minimum Bend Radius 60mm Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.08 Shipping Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range -40° to 158°F (-40° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported No CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 DISPLAYPORT (MALE) Connector Plating Nickel Contact Plating Gold Connector Style Straight Latching or Gripping Connector Yes FEATURES & SPECIFICATIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States EMI/RFI Line Noise Protection No MST Support Yes Antibacterial No IP68 Rated No Armored Cable No Ethernet Support No Displayport Specification 1.2 HDCP Specification 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P580-001 价格&库存
很抱歉,暂时无法提供与“P580-001”相匹配的价格&库存,您可以联系我们找货
