1000 Eaton Boulevard
Cleveland, OH 44122
United States
High-Speed HDMI Cable with Ethernet (M/M) - 4K,
CL3-Rated, 10 ft.
MODEL NUMBER: P569-010-CL3
Highlights
Supports UHD resolutions up to
4K (4:4:4) for crystal-clear video
Backward compatible with
previous HDMI generations
CL3-rated jacket supports inwall installation
Premium foil and braid shielding
protects against EMI/RFI noise
Package Includes
P569-010-CL3 High-Speed HDMI
Cable with Ethernet (M/M), 10 ft.
Transmits digital audio/video and Ethernet signals from an HDMI source to a 4K television, projector or
monitor. Ideal for in-wall home theater systems, digital signage and other applications that display UHD
video.
Description
The P569-010-CL3 High-Speed HDMI Cable (M/M) is ideal for home theater systems, digital signage and
other applications that display Ultra High Resolution (UHD) video and multi-channel audio. It connects an
HDMI-enabled source device, such as a Blu-ray player, video game system or computer, to a 4K-enabled
television, monitor or projector.
The P569-010-CL3 carries a CL3 rating, making it suitable for in-wall installation. It supports UHD video
resolutions up to 3840 x 2160 (4K x 2K), data transfer speeds up to 18 Gbps and 3D. The P569-010-CL3
works in all HDMI cabling scenarios.
This HDMI cable supports Ethernet data connectivity, which allows web-capable devices to share their
internet connection with other connected HDMI devices. An audio return channel simplifies setups
between displays and A/V receivers. When used with an Apple digital A/V adapter, it supports iPad2 video
mirroring for playing games, watching videos or displaying presentations.
The 10-foot (3.1-meter) molded 30 AWG cable features premium foil and braid shielding to deliver top-ofthe-line signal quality and protection from EMI/RFI interference. Gold-plated connectors ensure excellent
conductivity. Integral strain relief ensures the cable and connectors last a long time. A flexible CL3-rated
PVC jacket makes the cable easy to install in tight spaces.
Features
Connects HDMI Source to 4K TV, Projector or Monitor
● Ideal for home theater systems, digital signage and other applications that display UHD video and multichannel audio
CL3 rating suitable for in-wall installation
High Performance and Wide Compatibility
● Supports UHD and 3D video resolutions up to 4K
Supports iPad2 video mirroring when used with Apple digital A/V adapter
Works in all HDMI cabling scenarios
Superior Quality Ensures a Flawless Signal
● Fully molded 30 AWG construction with integral strain relief for durability and long life
Premium foil and braid shielding for EMI/RFI noise protection
1/4
Cleveland, OH 44122
United States
Corrosion-resistant gold-plated connectors for optimal signal transfer
Flexible PVC jacket easy to install in tight spaces
Specifications
OVERVIEW
UPC Code
037332197344
Technology
HDMI
Cable Type
Passive
VIDEO
Max Supported Video Resolution
3840 x 2160 @ 60Hz
Max Supported Color Depth
24-bit True Color
HDR Support
Yes
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
EDID Support
Yes
Signal Transmission
Unidirectional
AUDIO
Audio Specification
TrueHD/DTS-HD Master Audio bitstream
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PHYSICAL
Color
Black
Cable Jacket Color
Black
Connector Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
CL3
Cable Outer Diameter (OD)
6.0 mm
Wire Gauge (AWG)
30
Cable Length (ft.)
10
Cable Length (m)
3.05
Ferrite Core
No
Minimum Bend Radius
60mm
2/4
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / in.)
9.00 x 6.60 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 16.76 x 1.27
Shipping Weight (lbs.)
0.50
Shipping Weight (kg)
0.23
ENVIRONMENTAL
Operating Temperature Range
32 to 122 F (0 to 50 C)
Storage Temperature Range
14 to 176 F (-10 to 80 C)
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
COMMUNICATIONS
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Side A - Connector 1
HDMI (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
No
MST Support
No
Antibacterial
No
IP68 Rated
No
IP20 Rated
No
Armored Cable
No
Ethernet Support
Yes
Fire Rating
CL3 Rated
HDCP Specification
2.2
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
3/4
Cleveland, OH 44122
United States
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“P569-010-CL3”相匹配的价格&库存,您可以联系我们找货
