P569-016-CL3
P569-016-CL3
    TRIPPLITE
    HIGH-SPEEDHDMICABLEWITHETHER
P569-016-CL3 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High-Speed HDMI Cable with Ethernet (M/M) UHD 4K, In-Wall CL3-Rated, 16 ft. MODEL NUMBER: P569-016-CL3 Highlights ● Supports UHD resolutions up to 4K (4:4:4) for crystal-clear video ● 16 ft. length allows great flexibility in placing home theater or digital signage devices ● CL3-rated jacket supports inwall installation ● Premium foil and braid shielding protects against EMI/RFI noise Package Includes P569-016-CL3 High-Speed HDMI Cable with Ethernet (M/M), 16 ft. Transmits digital audio/video and Ethernet signals from an HDMI source to a 4K television, projector or monitor. Ideal for in-wall home theater systems, digital signage and other applications that display UHD video. Description The P569-016-CL3 High-Speed HDMI Cable (M/M) is ideal for home theater systems, digital signage and other applications that display Ultra High Resolution (UHD) video and multi-channel audio. It connects an HDMI-enabled source device, such as a Blu-ray player, video game system or computer, to a 4K-enabled television, monitor or projector. The P569-016-CL3 carries a CL3 rating, making it suitable for in-wall installation. It supports UHD video resolutions up to 3840 x 2160 (4K x 2K), data transfer speeds up to 18 Gbps and 3D. It works in all HDMI cabling scenarios. This HDMI cable supports Ethernet data connectivity, which allows web-capable devices to share their internet connection with other connected HDMI devices. An audio return channel simplifies setups between displays and A/V receivers. When used with an Apple digital A/V adapter, it supports iPad2 video mirroring for playing games, watching videos or displaying presentations. The 16-foot (4.9-meter) molded 30 AWG cable features premium foil and braid shielding to deliver top-ofthe-line signal quality and protection from EMI/RFI interference. Gold-plated connectors ensure excellent conductivity. Integral strain relief ensures the cable and connectors last a long time. A flexible CL3-rated PVC jacket makes the cable easy to install in tight spaces. Features Connects HDMI Source to 4K TV, Projector or Monitor ● Ideal for home theater systems, digital signage and other applications that display UHD video and multichannel audio ● CL3 rating suitable for in-wall installation High Performance and Wide Compatibility ● Supports UHD video resolutions up to 4K ● Supports iPad2 video mirroring when used with Apple digital A/V adapter ● Works in all HDMI cabling scenarios Superior Quality Ensures a Flawless Signal ● Fully molded 30 AWG construction with integral strain relief for durability and long life ● Premium foil and braid shielding for EMI/RFI noise protection 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Corrosion-resistant gold-plated connectors for optimal signal transfer ● Flexible PVC jacket easy to install in tight spaces Specifications OVERVIEW UPC Code 037332197351 Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 @ 60Hz Max Supported Color Depth 24-bit True Color HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Unidirectional AUDIO Audio Specification TrueHD/DTS-HD Master Audio bitstream USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating CL3 Cable Outer Diameter (OD) 7.3 mm Wire Gauge (AWG) 28 Cable Length (ft.) 16 Cable Length (m) 4.88 Ferrite Core No Minimum Bend Radius 73mm 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 9.06 x 7.08 x 0.50 Shipping Dimensions (hwd / cm) 23.01 x 17.98 x 1.27 Shipping Weight (lbs.) 0.75 Shipping Weight (kg) 0.34 ENVIRONMENTAL Operating Temperature Range 32 to 122 F (0 to 50 C) Storage Temperature Range 14 to 176 F (-10 to 80 C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support Yes Fire Rating CL3 Rated HDCP Specification 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P569-016-CL3 价格&库存
很抱歉,暂时无法提供与“P569-016-CL3”相匹配的价格&库存,您可以联系我们找货
P569-016-CL3
    库存:7
