P586-003-HDMI
P586-003-HDMI
    TRIPPLITE
    P586-003-HDMI
P586-003-HDMI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mini DisplayPort to HDMI Active Adapter Cable (M/M), 1080p, 3 ft. (0.9 m) MODEL NUMBER: P586-003-HDMI Highlights ● Supports video resolutions up to 1920 x 1080 (1080p) ● Supports audio and HDCP ● No separate power adapter required ● Designed for Dual-Mode DisplayPort++ graphics cards ● Gold-plated HDMI connector System Requirements ● Not for use with MST Hubs. For compatibility with MST Hubs, use a Displayport 1.2 compliant product such as P586-003-HDV2A Package Includes ● Connects the Mini DisplayPort™ (mDP) on your computer or laptop to an HDMI monitor, projector or television. Features Send High-Definition Mini DisplayPort Audio/Video Signals to an HDMI Display ● Connects mDP computer to HDMI-enabled monitor, projector or TV ● Ideal for displaying video on a large monitor or digital sign ● No separate power adapter required Vibrant Video Quality ● Supports HD video resolutions up to 1920 x 1080 (1080p) ● Supports audio and HDCP ● Designed for Dual-Mode DP++ graphics cards Superior Materials for Superior Performance ● Gold-plated HDMI connector and nickel-plated mDP connector for excellent conductivity ● Integral strain relief for long life Specifications OVERVIEW UPC Code 037332200495 Product Type Active Cable Technology HDMI; DisplayPort Cable Type Active 1/3 P586-003-HDMI Mini DisplayPort to HDMI Adapter Cable (M/M), 3 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States VIDEO Max Supported Video Resolution 1920 x 1200 (1080p) Max Supported Color Depth 12-bit True Color HDR Support No Chroma Sub Sampling 4:4:4 PHYSICAL Color Black Material of Construction ABS, PVC Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.8mm Wire Gauge (AWG) 32 Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Shipping Dimensions (hwd / in.) 0.50 x 4.50 x 3.90 Shipping Dimensions (hwd / cm) 1.27 x 11.43 x 9.91 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 158°F (-10° to 70°C) Operating Humidity Range 10% to 85%, Non-Condensing Storage Humidity Range 5% to 90%, Non-Condensing CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold; Nickel Contact Plating Gold FEATURES & SPECIFICATIONS IP68 Rated No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States IP20 Rated No Displayport Specification 1.1a HDCP Specification 1.3 STANDARDS & COMPLIANCE Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty Product Warranty Period (U.S. & Canada) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P586-003-HDMI
物料型号: - 型号编号:P586-003-HDMI
器件简介: - 该产品是一款Mini DisplayPort到HDMI的有源转接器线缆,支持1080p视频分辨率,无需额外电源适配器,适用于双模式DisplayPort++图形卡,具有镀金HDMI连接器。
引脚分配: - 侧A - 连接器1:MINI DISPLAYPORT(公头) - 侧B - 连接器1:HDMI(公头)
参数特性: - 最大支持视频分辨率:1920x1200(1080p) - 最大支持颜色深度:12-bit True Color - HDR支持:不支持 - 色度子采样:4:4:4 - 连接器镀层:镍 - 接触镀层:金
功能详解: - 支持高清视频分辨率高达1920x1080(1080p) - 支持音频和HDCP - 为双模式DP++图形卡设计 - 镀金HDMI连接器和镀镍mDP连接器,提供优异的导电性 - 内置应力消除,延长使用寿命
应用信息: - 将计算机或笔记本电脑上的Mini DisplayPort™连接到HDMI监视器、投影仪或电视 - 适合在大屏幕上显示视频或数字标牌 - 无需单独的电源适配器
封装信息: - 颜色:黑色 - 材料:ABS, PVC - 线缆外套颜色:黑色 - 线缆外套材料:PVC - 线缆外套等级:VW-1 - 线缆外径(OD):4.8mm - 线规(AWG):32 - 线缆长度(英尺):3 - 线缆长度(米):0.91 - 线缆长度(英寸):36
P586-003-HDMI 价格&库存
很抱歉,暂时无法提供与“P586-003-HDMI”相匹配的价格&库存,您可以联系我们找货
