P572-006
P572-006
    TRIPPLITE
    P572-006
P572-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High Speed Mini-HDMI Cable (M/M), 6 ft. Highlights ● Supports HD video resolutions up to 1080p ● Premium foil and braid shielding protects against EMI/RFI noise ● 24K gold-plated connectors for maximum conductivity MODEL NUMBER: P572-006 Package Includes Mini-HDMI to Mini-HDMI Cable M/M, 6 ft. Description Tripp Lite's six-foot Mini-HDMI to Mini-HDMI cable allows you to connect digital cameras, camcorders and other digital devices with the Mini-HDMI connector directly to your standard Mini-HDMI-enabled TV. Cable increases bandwidth to 340 MHz or about 10.2 Gbps. This means you get a more consistent, clean audio and video signal from point A to point B. 24K gold-plated connectors ensure the ultimate in error free signal transfer. RoHS compliant. Features Connects Mini-HDMI Devices ● Recommended for mobile users who want a cable that can easily pack away in a backpack, laptop bag or camera bag ● Ideal for connecting a mini-HDMI camcorder, digital camera or tablet to an mini HDMI display High Performance and Wide Compatibility ● Supports HD video resolutions up to 1080p ● Superior Quality Ensures a Flawless Signal ● 24K gold-plated connectors and contacts for maximum conductivity and minimum data loss ● Integral strain relief protects cable and connectors from stress and cracking ● Foil and braid shielding protects against EMI/RFI line noise that can distort or destroy data ● Flexible PVC jacket easy to install in tight spaces Specifications OVERVIEW UPC Code 037332137920 Product Type Passive Cable Technology HDMI Cable Type Passive 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States VIDEO Max Supported Video Resolution 1920 x 1200 (1080p) Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported No Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification DTS-HD USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.5 mm Wire Gauge (AWG) 30 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Ferrite Core No Minimum Bend Radius 27.5mm Shipping Dimensions (hwd / in.) 0.25 x 7.00 x 9.00 Shipping Dimensions (hwd / cm) 0.64 x 17.78 x 22.86 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Temperature Range 5° to 140°F (-15° to 60°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 MINI HDMI (MALE) Side B - Connector 1 MINI HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P572-006 价格&库存
很抱歉,暂时无法提供与“P572-006”相匹配的价格&库存,您可以联系我们找货
