P134-003
P134-003
    TRIPPLITE
    DISPLAYPORT TO VGA ADAPTER
P134-003 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort to DVI Cable Adapter, Converter for DP-M to DVI-I-F, 3 ft. (0.91 m) MODEL NUMBER: P134-003 Highlights ● Connect a DVI monitor to a computer with a DisplayPort output ● Plug-and-play convenience; no drivers or software needed ● Supports DVI-D single-link computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p ● This product is a passive adapter and requires that the connected computer has a DP++ (DisplayPort ++) dualmode port System Requirements ● A computer with a DisplayPort output ● A monitor with a DVI port ● The P134-003 is a passive adapter, and requires that the connected computer has a DP++ ( DisplayPort ++ ) port, which allows HDMI and DVI signals to be passed through; check the documentation for your DisplayPort source for compatibility. ● Not for use with MST Hubs. For compatibility with MST Hubs, use a Displayport 1.2 compliant product such as P134-06N-DVIV2 Description Tripp Lite's P134-003, 3-ft. (0.91 m) DisplayPort to DVI Adapter Converter, allows you to connect a computer with a DisplayPort connection to a DVI monitor. Digital Video DisplayPort signals are passed through with support for DVI single-link computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p. Fully molded ends ensure long life enjoyment. The P134-003 is a passive adapter and requires that the connected computer has a DP++ ( DisplayPort ++ ) port, which allows HDMI and DVI signals to be passed through. Check the documentation for your DisplayPort source for compatibility. Features ● Connect a DVI monitor to a computer with a DisplayPort output ● DisplayPort to DVI Adapter Converter (DisplayPort-Male to DVI-I-Female), 3-ft. (0.91 m) ● Supports DVI single-link computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p ● Fully molded ends ● The P134-003 is a passive adapter, and requires that the connected computer has a DP++ ( DisplayPort ++ ) port, which allows HDMI and DVI signals to be passed through; check the documentation for your DisplayPort source for compatibility. Specifications OVERVIEW UPC Code 037332186492 Product Type Video Adapter Technology DVI; DisplayPort PHYSICAL Color Black 1/2 Package Includes ● DisplayPort to DVI Cable Adapter, Converter for DP-M to DVI-I-F, 3-ft. (0.91 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Color Black Cable Length (m) 1 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.26 Shipping Weight (kg) 0.12 CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 DVI-I (FEMALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P134-003 价格&库存
很抱歉,暂时无法提供与“P134-003”相匹配的价格&库存,您可以联系我们找货
P134-003
    • 1+165.670141+21.47401
    • 10+140.8228210+18.25332
    • 25+132.0057225+17.11046
    • 50+125.7053450+16.29381
    • 100+119.70826100+15.51647
    • 250+112.22028250+14.54589
    • 500+106.87005500+13.85240
    库存:15
