EZB-DVIM-2
EZB-DVIM-2
    TRIPPLITE
    EZB-DVIM-2
EZB-DVIM-2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Easy Pull Type-B Connectors - (M/M set of DVISingle-Link) MODEL NUMBER: EZB-DVIM-2 Highlights ● DVI-D Connector Kit includes: 2 x DVI-D Male 1-ft. (0.31 m) Cables ● Versatile trunk cable allows for a variety of connection options ● High quality digital cable supports resolutions up to 1080p ● Requires B120-000 DVI signal booster Package Includes Description Easy Pull Connector Kit includes: 2 x DVI-D Single Link Male Cable - 1-ft. (0.31 m) pigtail. Completes your Easy Pull trunk run with a finished appearance. Digital video support up to 1080p. Use with either PVC or Plenum digital trunk cables. Requires B120-000 DVI signal booster. Features ● Eliminates the need to field terminate DVI connectors ● Allows cable to be run according to code - inside conduit, drop ceilings, etc. ● Makes pulling long cables fast and easy ● Digital trunk cables available in 50-ft. (15.24 m) and 100-ft. (30.5 m) lengths ● Requires B120-000 DVI signal booster ● High quality digital cable supports resolutions up to 1080p Specifications OVERVIEW UPC Code 037332141910 Technology DVI Cable Type Passive PHYSICAL Color Black; Yellow Cable Length (ft.) 1 Cable Length (m) 0.30 1/2 ● 2 x DVI-D Male 1-ft. (0.31 m) Pigtail Cable ● Requires B120-000 DVI signal booster (not included) 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.36 Shipping Weight (kg) 0.16 CONNECTIONS Side A - Connector 1 DVI-D SINGLE LINK (MALE) Side A - Connector 2 DIN 19 PIN (MALE) Side B - Connector 1 DVI-D SINGLE LINK (MALE) Side B - Connector 2 DIN 19 PIN (MALE) Latching or Gripping Connector No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
EZB-DVIM-2 价格&库存
很抱歉,暂时无法提供与“EZB-DVIM-2”相匹配的价格&库存,您可以联系我们找货
