P568-035
P568-035
    TRIPPLITE
    P568-035
P568-035 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States In some applications where the HDMI cable exceeds 16ft, a signal booster (B122-000-60) will need to be used with this cable to ensure a signal strong enough for your display. High-Speed HDMI Cable, HD, Digital Video with Audio (M/M), Black, 35 ft. (10.67 m) Highlights ● 35-ft. (10.67 m), Premium double-shielded digital audio/video cable ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Bandwidth up to 18 Gbps - Full 1080p resolution ● High Speed HDMI and HDCP compliant ● Supports High Definition (HD) video resolutions up to 1080p MODEL NUMBER: P568-035 System Requirements ● HDMI Video Source ● HDMI Video Display Package Includes ● Description Tripp Lite's 35-ft. (10.67 m) High Speed HDMI (High-Definition Multimedia Interface) Gold Cable allows interconnection between digital display devices, such as DTV's (Digital Television), Plasma displays, LCD TV's and projectors, to Digital source devices, such as Digital Set-Top boxes, Blu-Ray players and AV receivers. Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter. HDMI assures that the best audio/video signal is always sent from the source (HDTV signal, Blu-Ray Player) to the display (Projection Television, LCD, Plasma, etc.). It does this by allowing uncompressed video and multi-channel audio data to be input to the display device through one single cable. An HDMI connection allows input at high rates of speed, up to 18 Gbps. Features ● Creates a pure digital connection between HDMI-enabled HDTV display devices and HDMI-enabled digital video sources ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Premium double-shielded cable protects against outside noise (EMI/RFI) ● Impedance-matched twisted-pair construction reduces cross-talk and interference ● Bandwidth up to 18 Gbps - Full 1080p resolution ● Perfect for connecting an iPad2 to an HDTV (video mirroring) to watch movies, play games, surf the web and display presentations ( when used with iPad to HDMI adapter ) ● Supports High Definition (HD) video resolutions up to 1080p Specifications OVERVIEW UPC Code 037332179883 1/4 35-ft. (10.67 m) High Speed HDMI Gold Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Type Passive Cable Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 (4K) @ 30Hz Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification ARC USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 7.3 mm Wire Gauge (AWG) 28 Cable Length (ft.) 35 Cable Length (m) 10.67 Cable Length (in.) 420 Ferrite Core No Minimum Bend Radius 36.5mm Shipping Dimensions (hwd / in.) 10.00 x 12.00 x 1.00 Shipping Dimensions (hwd / cm) 25.40 x 30.48 x 2.54 Shipping Weight (lbs.) 1.70 Shipping Weight (kg) 0.77 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P568-035 价格&库存
很抱歉,暂时无法提供与“P568-035”相匹配的价格&库存,您可以联系我们找货
P568-035
    • 1+499.082341+64.64862
    • 10+424.2189310+54.95119
    • 25+397.6732425+51.51260
    • 50+378.7100350+49.05620
    • 100+364.36609100+47.19816
    库存:7
