P568-040
P568-040
    TRIPPLITE
    HIGH-SPEEDHDMICABLEWITHDIGIT
P568-040 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States In some applications where the HDMI cable exceeds 16ft, a signal booster (B122-000-60) will need to be used with this cable to ensure a signal strong enough for your display. High-Speed HDMI Cable, HD, Digital Video with Audio (M/M), Black, 40 ft. (12.19 m) MODEL NUMBER: P568-040 Highlights ● Supports HD (High Definition) video resolutions up to 1080p ● Supports data transfer speeds up to 18 Gbps ● Backward compatible with previous HDMI generations ● Premium foil and braid shielding protects against EMI/RFI noise ● Gold-plated black connectors for optimal signal transfer Package Includes ● High-speed premium cable connects two HD HDMI-enabled devices, including computers, Blu-ray™ players, video game systems, DVRs, video cameras, A/V receivers, monitors, projectors and televisions. Description The P568-040 High-Speed HDMI Cable (M/M) is ideal for digital signage, video presentations, point-ofsale displays, classrooms and other applications that display High Definition (HD) video and multi-channel audio. It connects HDMI-enabled source devices, such as computers and Blu-ray™ players, to HDMIenabled displays, such as monitors, projectors and high-definition televisions. This cable supports HD video resolutions up to 1080p and data transfer speeds up to 18 Gbps—the fastest bandwidth currently available over HDMI. When used with an Apple® digital A/V adapter, it supports iPad2® video mirroring for playing games, watching videos or displaying presentations. Backward compatible with previous HDMI generations, the P568-040 works in all HDMI cabling scenarios. The 40-ft. (12.19 m) molded 28 AWG cable features premium foil and braid shielding to deliver top-of-theline signal quality and protection from EMI/RFI interference. Gold-plated black connectors ensure excellent conductivity. Integral strain relief ensures the cable and connectors last a long time. A flexible PVC jacket makes the cable easy to install in tight spaces. Features Connects HDMI Source to TV, Projector or MonitorRecommended for digital signage, video presentations, point-of-sale displays, classrooms and other applications that display HD video and multichannel audio High Performance and Wide CompatibilitySupports HD video resolutions up to 1080pSupports data transfer speeds up to 18 GbpsSupports iPad2 video mirroring when used with Apple digital A/V adapterBackward compatible with previous HDMI generations Superior Quality Ensures a Flawless SignalCorrosion-resistant gold-plated black connectors for optimal signal transferFully molded 28 AWG construction with integral strain relief for durability and long lifePremium foil and braid shielding for EMI/RFI noise protectionFlexible PVC jacket easy to install in tight spaces Specifications 1/4 P568-040 High-Speed HDMI Cable with Digital Video and Audio (M/M), Black, 40-ft. (12.19 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332200464 Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 @ 30Hz Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification ARC USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 7.3 mm Wire Gauge (AWG) 28 Cable Length (ft.) 40 Cable Length (m) 12.20 Ferrite Core No Minimum Bend Radius 36.5mm Shipping Dimensions (hwd / in.) 12.00 x 9.50 x 0.50 Shipping Dimensions (hwd / cm) 30.48 x 24.13 x 1.27 Shipping Weight (lbs.) 1.80 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 0.82 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P568-040 价格&库存
很抱歉,暂时无法提供与“P568-040”相匹配的价格&库存,您可以联系我们找货
