P568-025-EZ
P568-025-EZ
    TRIPPLITE
    P568-025-EZ
P568-025-EZ 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States In some applications where the HDMI cable exceeds 16ft, a signal booster (B122-000-60) will need to be Highlights used with this cable to ensure a signal strong enough for your display. ● HDMI Easy Pull Cable, Digital Video with Audio (M/M), 25 ft. 2-piece design runs through conduit or other tight areas ● Threaded circular DIN connector provides secure reattachment ● Superior-molded cables with foil and braid shielding for maximum EMI/RFI protection ● Bandwidth up to 10.2 Gbps Full 1080p resolution ● Supports High Definition (HD) video resolutions up to 1080p MODEL NUMBER: P568-025-EZ Package Includes HDMI Easy Pull Cable, HD 1080p, Digital Video with Audio (M/M), 25 ft. Description Tripp Lite's 25-foot (7.6-meter) HDMI Easy Pull Monitor Cable w/ Connectors makes running long video cables a snap. The pull-apart design allows the cable to run through conduit or other tight areas that a HDMI connector wouldn't fit through. Diameter of the circular DIN end is only 7/8 inch. Circular Easy Pull connector is threaded to ensure maximum security once the cable is reattached. Double shielding (foil and braid) provides maximum EMI/RFI protection. Both HDMI male ends are molded and have integral strain relief to provide long life. UL20276 Digital Video Cable supports 1080p. In most applications, a signal booster (B122-000-60) will need to be used with this cable to ensure a signal strong enough for your display. Features ● 2-piece design runs through conduit or other tight areas ● Threaded circular DIN connector provides secure reattachment ● Superior-molded cables with foil and braid shielding for maximum EMI/RFI protection ● High quality quad-shielded cable with gold connectors and pins ● Bandwidth up to 10.2 Gbps - Full 1080p resolution as specified by HDMI 1.2 ● In most applications where the HDMI cable exceeds 16 ft., a signal booster (B122-000-60) will need to be used with this cable to ensure a signal strong enough for your display ● HDMI male to male molded connectors ● UL20276 Digital Video Cable ● Supports High Definition (HD) video resolutions up to 1080p Specifications OVERVIEW 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332175564 Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 1920 x 1080 @ 60Hz Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported No Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification DTS-HD USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 6.5 mm Wire Gauge (AWG) 28 Cable Length (ft.) 25 Cable Length (m) 7.62 Ferrite Core No Minimum Bend Radius 32.5mm Shipping Dimensions (hwd / in.) 1.00 x 6.90 x 8.80 Shipping Dimensions (hwd / cm) 2.54 x 17.53 x 22.35 Shipping Weight (lbs.) 0.90 Shipping Weight (kg) 0.41 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 DIN 19 PIN (MALE) Connector Plating Gold; Nickel Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P568-025-EZ
- 物料型号: P568-025-EZ - 器件简介: 这是一款25英尺(7.6米)长的HDMI Easy Pull Monitor Cable,设计用于通过管道或其他狭窄区域,具有分离式设计。 - 引脚分配: 连接器为HDMI公头至DIN19PIN公头。 - 参数特性: - 带宽高达10.2 Gbps,支持全1080p分辨率。 - 支持高清视频分辨率高达1080p。 - 支持48位深颜色。 - 支持DTS-HD音频规格。 - 具有双向信号传输能力。 - 支持EDID。 - 符合HDCP 1.4和2.2规范。 - 功能详解: - 2件式设计,可穿过管道或其他狭窄区域。 - 圆形DIN连接器带有螺纹,确保重新连接时的安全性。 - 双屏蔽(箔和编织)提供最大的电磁干扰/射频干扰保护。 - 高质量的四屏蔽电缆,带有金连接器和引脚。 - 应用信息: 通常在HDMI电缆超过16英尺的应用中,需要使用信号增强器(B122-000-60)以确保信号足够强。 - 封装信息: - 电缆颜色:黑色。 - 材料:PVC。 - 电缆外径:6.5mm。 - 线规(AWG):28。 - 电缆长度:25英尺(7.62米)。
P568-025-EZ 价格&库存
很抱歉,暂时无法提供与“P568-025-EZ”相匹配的价格&库存,您可以联系我们找货
