P568-050-P
P568-050-P
    TRIPPLITE
    P568-050-P
P568-050-P 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States In some applications, a signal booster (Model Number: B122-000-60) should be used with this cable to ensure a signal strong enough for your display. An alternate solution is to use a Tripp Lite HDMI over Cat5 Highlights ● Plenum-rated for use where local code calls for a fire resistant cable ● Premium double-shielded digital audio/video cable ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Bandwidth up to 10.2 Gbps Full 1080p resolution ● Standard Speed HDMI and HDCP compliant ● Supports HD Video resolutions up to 1080p Extender (Model Number: B126-1A1) in place of a 50 ft. HDMI cable and signal booster. Standard-Speed HDMI Plenum Rated Cable, Digital Video with Audio (M/M), 50 ft. (15.24 m) MODEL NUMBER: P568-050-P Package Includes ● Features ● Plenum-rated for use where local code calls for a fire resistant cable ● Creates a pure digital connection between HDMI-enabled HDTV display devices and HDMI-enabled digital video sources ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Premium double-shielded cable protects against outside noise (EMI/RFI) ● Impedance-matched twisted-pair construction reduces cross-talk and interference ● Bandwidth up to 10.2 Gbps - Full 1080p resolution ● In most applications, a signal booster (B122-000-60) will need to be used with this cable to ensure a signal strong enough for your display Specifications OVERVIEW UPC Code 037332149985 Product Type Passive Cable Technology HDMI Cable Type Passive VIDEO 1/3 Standard Speed HDMI Plenum Rated Cable, 1080p, Digital Video with Audio (M/M), 50-ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Max Supported Video Resolution 1920 x 1200 (1080p) Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported No Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification DTS-HD USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating CMP Cable Outer Diameter (OD) 10.0 mm Wire Gauge (AWG) 24 Cable Length (ft.) 50 Cable Length (m) 15.24 Cable Length (in.) 600 Ferrite Core No Minimum Bend Radius 50mm Shipping Dimensions (hwd / in.) 14.00 x 17.00 x 1.00 Shipping Dimensions (hwd / cm) 35.56 x 43.18 x 2.54 Shipping Weight (lbs.) 5.30 Shipping Weight (kg) 2.40 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Operating Humidity Range 0% to 90% RH, Non-Condensing 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No Fire Rating Plenum Rated HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P568-050-P
物料型号:P568-050-P 器件简介:这是一根标准速度HDMI有线电缆,支持1080p分辨率的高清视频和音频传输,长度为50英尺(15.24米),并且具有防火等级。
引脚分配:HDMI公头对HDMI公头 参数特性: - 支持最大视频分辨率:1920 x 1200 (1080p) - 最大支持颜色深度:48位深颜色 - HDR支持:不支持 - 3D视频支持:不支持 - 色度子采样:4:4:4 - EDID支持:是 - 信号传输:双向 - 音频规格:DTS-HD 功能详解: - 支持iPad2视频镜像,需配合苹果数字AV适配器使用 - 金镀连接器提供最佳信号传输 - 高级双层屏蔽电缆,防止外部噪声(EMI/RFI) - 阻抗匹配的双绞线结构减少串扰和干扰 - 带宽高达10.2 Gbps,支持全1080p分辨率 应用信息:适用于需要防火电缆的场合,如商业环境、会议室、家庭影院等。
封装信息: - 颜色:黑色 - 材料:PVC - 电缆外径:10.0毫米 - 线规(AWG):24 - 电缆长度:50英尺(15.24米) - 最小弯曲半径:50毫米 - 连接器颜色:黑色 - 电缆防火等级:Plenum Rated - HDCP规格:1.4;2.2 - 产品符合性:RoHS; REACH - 产品保修期:全球范围内的有限终身保修
P568-050-P 价格&库存
很抱歉,暂时无法提供与“P568-050-P”相匹配的价格&库存,您可以联系我们找货
