1000 Eaton Boulevard
Cleveland, OH 44122
United States
In some applications, a signal booster (Model Number: B120-000-SL) should be used with this cable to
ensure a signal strong enough for your display. An alternate solution is to use a Tripp Lite DVI over Cat5
Highlights
Two-piece design runs through
conduit or other tight areas
Threaded circular DIN connector
provides secure reattachment
High Speed Digital
Transmission to 9.9Gbps
Superior molded cables with
foil/braid shielding for maximum
EMI/RFI protection
Contstructed using 24AWG wire
for optimal performance
Extender (Model Number: B140-101X) in place of a 100 ft. DVI cable and signal booster.
DVI Single Link Easy Pull Digital TMDS Monitor
Cable (DVI-D M/M), 100 ft. (30.5 m)
MODEL NUMBER: P561-100-EZ
Package Includes
Description
Tripp Lite's 100-ft. (30.5 m) DVI-D Single Link Easy Pull All-in-One Monitor Cable makes running long
length video cables a snap. The pull-apart design allows the cable to be run through conduit or other tight
areas that a DVI connector wouldn't fit through. Diameter of the circular DIN end is only 7/8". Circular
Easy Pull connector is threaded to ensure maximum security once the cable is reattached. Use in
conjunction with DVI video cards that are specified as Single Link. DVI connectors are molded, have
integral strain relief for long life reliability, and a ferrite collar to drain off extraneous electrical interference.
The P561-100-HD is constructed using 24AWG wire for optimal performance. In most applications, a
signal booster (B120-000-SL) will need to be used with this cable to ensure a signal strong enough for
your display.
Features
Two-piece design runs through conduit or other tight areas
Threaded circular DIN connector provides secure reattachment
For use with Single Link TMDS specified equipment
Compatible with Flat Panel Displays, Digital CRT Displays and Projectors
High Speed Digital Transmission to 9.9Gbps
Superior molded cables with foil/braid shielding for maximum EMI/RFI protection
Constructed using 24AWG wire for optimal performance
In most applications, a signal booster (B120-000-SL) will need to be used with this cable to ensure a
Specifications
OVERVIEW
1/2
100-ft. (30.5 m) Easy Pull All-inOne DVI Single Link Cable
(DVI-D M/M)
Cleveland, OH 44122
United States
UPC Code
037332142252
Product Type
Passive Cable
Technology
DVI
Cable Type
Passive
PHYSICAL
Color
Black
Cable Jacket Color
Black
Cable Length (ft.)
100
Cable Length (m)
30.49
Cable Length (in.)
1200
Shipping Dimensions (hwd / in.)
17.00 x 14.00 x 0.50
Shipping Dimensions (hwd / cm)
43.18 x 35.56 x 1.27
Shipping Weight (lbs.)
6.20
Shipping Weight (kg)
2.81
CONNECTIONS
Side A - Connector 1
DVI-D SINGLE LINK (MALE)
Side B - Connector 1
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“P561-100-EZ”相匹配的价格&库存,您可以联系我们找货
