P561-075
P561-075
    TRIPPLITE
    P561-075
P561-075 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States In some applications, a signal booster (Model Number: B120-000-SL) should be used with this cable to ensure a signal strong enough for your display. An alternate solution is to use a Tripp Lite DVI over Cat5 Highlights ● For use with Single Link TMDS specified equipment ● Compatible with Flat Panel Displays, Digital CRT Displays and Projectors ● Provides bandwidth for resolutions up to 1920 x 1200 ● High Speed Digital Transmission to 9.9Gbps ● Superior molded cables with foil/braid shielding for maximum EMI/RFI protection Extender (Model Number: B140-101X) in place of a 75 ft. DVI cable and signal booster. DVI Single Link Cable, Digital TMDS Monitor Cable (DVI-D M/M), 75 ft. (22.86 m) MODEL NUMBER: P561-075 System Requirements ● DVI monitor and computer Package Includes ● Description Tripp Lite's 75-ft. (22.86 m) DVI Single Link TMDS cable delivers the high performance, high bandwidth needed for today's digital video displays. Gold plated contacts ensure excellent conductivity, while double shielding (foil and braid) provides maximum EMI/RFI protection. Use in conjunction with DVI video cards that are specified as Single Link. Both DVI connectors are molded, have integral strain relief for long life reliability, and ferrite collars to drain off extraneous electrical interference. In most applications, a signal booster (B120-000-SL) will need to be used with this cable to ensure a signal strong enough for your display. Features ● For use with Single Link TMDS specified equipment ● Compatible with Flat Panel Displays, Digital CRT Displays and Projectors ● Provides bandwidth for resolutions up to 1920 x 1200 ● High Speed Digital Transmission to 9.9Gbps ● Superior molded cables with foil/braid shielding for maximum EMI/RFI protection ● In most applications, a signal booster (B120-000-SL) will need to be used with this cable to ensure a signal strong enough for your display Specifications OVERVIEW UPC Code 037332168580 Product Type Passive Cable Technology DVI 1/2 75-ft. (22.86 m) DVI Single Link TMDS Cable (DVI-D M/M) 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Type Passive PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 75 Cable Length (m) 22.87 Cable Length (in.) 900 Shipping Dimensions (hwd / in.) 17.00 x 14.00 x 1.00 Shipping Dimensions (hwd / cm) 43.18 x 35.56 x 2.54 Shipping Weight (lbs.) 3.20 Shipping Weight (kg) 1.45 CONNECTIONS Side A - Connector 1 DVI-D SINGLE LINK (MALE) Side B - Connector 1 DVI-D SINGLE LINK (MALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P561-075 价格&库存
很抱歉,暂时无法提供与“P561-075”相匹配的价格&库存,您可以联系我们找货
