P568-100-HD
P568-100-HD
    TRIPPLITE
    HDMIGOLDCABLEM/M100'
P568-100-HD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States In some applications, a signal booster (Model Number: B122-000-60) should be used with this cable to ensure a signal strong enough for your display. If transmitting a 1920 x 1080 (1080p) signal, you should Highlights ● 24AWG High Definition Standard Speed HDMI Gold cable ● Premium double-shielded digital audio/video cable ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Standard Speed HDMI and HDCP compliant ● Supports HD Video resolutions up to 1080p use the High Definition version of this cable (Model Number: P568-100-HD), in addition to a signal booster. An alternate, more cost-effective solution is to use a Tripp Lite HDMI over Cat5 Extender (Model Number: B126-1A1) in place of a 100 ft. HDMI cable and signal booster. Standard-Speed HDMI Cable, 24 AWG High Definition, Digital Video with Audio Cable (M/M), 100 ft. (30.5 m) MODEL NUMBER: P568-100-HD Package Includes ● Description Tripp Lite's 100-ft. (30.5 m) 24AWG High Definition Standard Speed HDMI Gold cable allows interconnection between digital display devices, such as DTV's ( Digital Television ), Plasma displays, LCD TV's, and projectors, to Digital source devices, such as Digital Set-Top boxes, Blu-Ray players, and AV receivers. Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter. Heavy gauge wire ( 24AWG) assures full 1080p resolution at the display when used with a Tripp Lite HDMI Signal Booster, such as the B122-000-60. HDMI assures that the best video signal is always sent from source (HDTV signal, Blu-Ray Player) to the display (Projection Television, LDC, Plasma, etc.). It does this by allowing uncompressed video and multi-channel audio data to be input to the display device through one single cable. An HDMI connection allows input at high rates of speed, up to 10.2 Gbps. Features ● 24AWG High Definition Standard Speed HDMI Gold Cable ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Premium Double-Shielded cable protects against outside noise (EMI/RFI) ● Impedance matched twisted pair construction reduces cross-talk and interference ● Bandwidth up to 10.2 Gbps - Full 1080p resolution ● In most applications, a signal booster (B122-000-60) will need to be used with this cable to ensure a signal strong enough for your display Specifications 1/4 100-ft. (30.5 m) 24AWG High Definition Standard Speed HDMI Gold Cable (HDMI M/M) 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332153401 Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 1920 x 1080 @ 60Hz Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported No Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification DTS-HD USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 9.0 mm Wire Gauge (AWG) 24 Cable Length (ft.) 100 Cable Length (m) 30.49 Ferrite Core No Minimum Bend Radius 45mm Shipping Dimensions (hwd / in.) 17.00 x 14.00 x 1.00 Shipping Dimensions (hwd / cm) 43.18 x 35.56 x 2.54 Shipping Weight (lbs.) 7.80 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 3.54 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P568-100-HD 价格&库存
很抱歉,暂时无法提供与“P568-100-HD”相匹配的价格&库存,您可以联系我们找货
