P561-050-EZ
P561-050-EZ
    TRIPPLITE
    P561-050-EZ
P561-050-EZ 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI Single Link Easy Pull Digital TMDS Monitor Cable (DVI-D M/M), 50 ft. (15.24 m) MODEL NUMBER: P561-050-EZ Highlights ● Two-piece design runs through conduit or other tight areas ● Threaded circular DIN connector provides secure reattachment ● For use with Single Link TMDS specified equipment ● Compatible with Flat Panel Displays, Digital CRT Displays and Projectors ● Provides bandwidth for resolutions up to 1920 x 1200 ● High Speed Digital Transmission to 9.9Gbps ● Superior molded cables with foil/braid shielding for maximum EMI/RFI protection Package Includes ● Description Tripp Lite's 50-ft. (15.24 m) DVI-D Single Link Easy Pull All-in-One Monitor Cable makes running long length video cables a snap. The pull-apart design allows the cable to be run through conduit or other tight areas that a DVI connector wouldn't fit through. Diameter of the circular DIN end is only 7/8". Circular Easy Pull connector is threaded to ensure maximum security once the cable is reattached. Use in conjunction with DVI video cards that are specified as Single Link. DVI connectors are molded, have integral strain relief for long life reliability, and a ferrite collar to drain off extraneous electrical interference. In most applications, a signal booster (B120-000-SL) will need to be used with this cable to ensure a signal strong enough for your display. Features ● Two-piece design runs through conduit or other tight areas ● Threaded circular DIN connector provides secure reattachment ● For use with Single Link TMDS specified equipment ● Compatible with Flat Panel Displays, Digital CRT Displays and Projectors ● Provides bandwidth for resolutions up to 1920 x 1200 ● High Speed Digital Transmission to 9.9Gbps ● Superior molded cables with foil/braid shielding for maximum EMI/RFI protection ● In most applications, a signal booster (B120-000-SL) will need to be used with this cable to ensure a signal strong enough for your display Specifications OVERVIEW UPC Code 037332142290 Technology DVI Cable Type Passive 1/2 50-ft. (15.24 m) Easy Pull All-inOne DVI Single Link Cable (DVI-D M/M) 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 50 Cable Length (m) 15.24 Shipping Dimensions (hwd / in.) 12.00 x 10.00 x 1.00 Shipping Dimensions (hwd / cm) 30.48 x 25.40 x 2.54 Shipping Weight (lbs.) 2.80 Shipping Weight (kg) 1.27 CONNECTIONS Side A - Connector 1 DVI-D SINGLE LINK (MALE) Side B - Connector 1 DVI-D SINGLE LINK (MALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P561-050-EZ 价格&库存
很抱歉,暂时无法提供与“P561-050-EZ”相匹配的价格&库存,您可以联系我们找货
