1000 Eaton Boulevard
Cleveland, OH 44122
United States
In some applications, a signal booster (Model Number: B122-000-60) should be used with this cable to
ensure a signal strong enough for your display. If transmitting a 1920 x 1080 (1080p) signal, you should
Highlights
Two-piece design runs through
conduit or other tight areas
Threaded circular DIN connector
provides secure reattachment
Number: B126-1A1) in place of a 100 ft. HDMI cable and signal booster.
Standard-Speed HDMI Easy Pull Cable, Digital
Video with Audio (M/M), 100 ft. (30.5 m)
Supports iPad2 Video Mirroring
when used with Apple Digital AV
Adapter
MODEL NUMBER: P568-100-EZ
Bandwidth up to 10.2 Gbps Full 1080p resolution
Standard Speed HDMI and
HDCP compliant
Supports HD Video resolutions
up to 1080p
use the High Definition version of this cable (Model Number: P568-100-HD), in addition to a signal
booster. An alternate, more cost-effective solution is to use a Tripp Lite HDMI over Cat5 Extender (Model
Package Includes
Description
Tripp Lite's 100-ft. (30.5 m) Standard Speed HDMI Easy Pull All-in-One Monitor Cable makes running long
length video cables a snap. The pull-apart design allows the cable to be run through conduit or other tight
areas that a HDMI connector wouldn't fit through. Diameter of the circular DIN end is only 7/8". Circular
Easy Pull connector is threaded to ensure maximum security once the cable is reattached. Supports
iPad2 Video Mirroring when used with Apple Digital AV Adapter. HDMI assures that the best audio/video
signal is always sent from the source (HDTV signal, Blu-Ray Player) to the display (Projection Television,
LCD, Plasma, etc.). It does this by allowing uncompressed video and multi-channel audio data to be input
to the display device through a single cable. An HDMI connection allows input at high rates of speed, up
to 10.2 Gbps. In most applications, a signal booster (B122-000-60) will need to be used with this cable to
Features
Two-piece design runs through conduit or other tight areas
Threaded circular DIN connector provides secure reattachment
Creates a pure digital connection between HDMI-enabled HDTV display devices and HDMI-enabled
digital video sources
Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter
Gold-plated connectors provide optimal signal transfer
Premium double-shielded cable protects against outside noise (EMI/RFI)
Impedance-matched twisted-pair construction reduces cross-talk and interference
Bandwidth up to 10.2 Gbps - Full 1080p resolution
In most applications, a signal booster (B122-000-60) will need to be used with this cable to ensure a
1/4
Pull Cable, 1080p, Digital Video
with Audio (M/M), 100-ft. (30.5
m)
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332142221
Product Type
Passive Cable
Technology
HDMI
Cable Type
Passive
VIDEO
Max Supported Video Resolution
1920 x 1200 (1080p)
Max Supported Color Depth
48-bit Deep Color
HDR Support
No
3D Video Supported
No
Chroma Sub Sampling
4:4:4
EDID Support
Yes
Signal Transmission
Bidirectional
AUDIO
Audio Specification
DTS-HD
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PHYSICAL
Color
Black
Material of Construction
PVC
Cable Jacket Color
Black
Connector Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
6.5 mm
Wire Gauge (AWG)
28
Cable Length (ft.)
100
Cable Length (m)
30.49
Cable Length (in.)
1200
Ferrite Core
No
Minimum Bend Radius
32.5mm
2/4
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / in.)
4.00 x 4.50 x 9.40
Shipping Dimensions (hwd / cm)
10.16 x 11.43 x 23.88
Shipping Weight (lbs.)
6.25
Shipping Weight (kg)
2.83
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Side A - Connector 1
HDMI (MALE)
Side B - Connector 1
DIN 19 PIN (MALE)
Connector Plating
Gold; Nickel
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
No
MST Support
No
Antibacterial
No
IP68 Rated
No
IP20 Rated
No
Armored Cable
No
Ethernet Support
No
HDCP Specification
1.4; 2.2
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
3/4
Cleveland, OH 44122
United States
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“P568-100-EZ”相匹配的价格&库存,您可以联系我们找货
