3239-20-1-0500-004-1-TS
    CNC
    SILICON WIRE 20AWG RD 25'
3239-20-1-0500-004-1-TS 数据手册
P/N 3239-20-1-0500-0XX-1-TS UL3239 - Silicone Rubber Wire 150°C 3KV (20 AWG) CONSTRUCTION: Tinned Strands, copper conductor, 21/0.18mm strands. Overall Diameter = 1.85mm (+ +/0.10mm Insulation Thickness: 0.55mm CERTIFICATION & APPROVALS: DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: “AWM 3239 150℃ 3KVDC VW-1 20AWG E108485-S REIHSING CSA TYPE TV-3 150℃ 3KVDC 20AWG LL84687 FT1 SILICONE RUBBER” Passes UL VW-1 & CSA FT1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: Rated Temperature: 150℃ ~ -50℃ Rated Voltage: 3KV Insulation Potential Strength: 6000 VAC/min High flexibility: Soft silicone rubber material. Maximum Conductor Resistance: 39.5Ω/km Resistant to: Oil, extremes of hot & cold, flexing, high Voltage spikes. Silicone rubber wire, has high temperature resistance and high flexibility in confined spaces. Suitable for use in LED TVs, Laptops, Microwaves, Photocopiers, Scanners. APPLICATIONS: PACKAGING: 500ft per reel. ENVIRONMENTAL APPROVALS: Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 3239-20-1-0500-001-1-TS 3239-20-1-0500-002-1-TS 3239-20-1-0500-003-1-TS 3239-20-1-0500-004-1-TS 3239-20-1-0500-005-1-TS ! 3239-20-1-0500-006-1-TS " 3239-20-1-0500-007-1-TS # " 3239-20-1-0500-008-1-TS0 3239-20-1-0500-010-1-TS "# $ 3239-20-1-0500-011-1-TS # "%
物料型号为3239-20-1-0500-0XX-1-TS,其中“XX”代表不同的颜色代码。
器件简介为UL3239硅橡胶线,具有150°C的耐温性和3KV的耐压性,适用于20AWG规格。
引脚分配未在文档中明确说明。
参数特性包括导体为镀锡铜丝,绝缘层为硅橡胶,额定温度范围为-50°C至150°C,额定电压为3KV,绝缘耐压强度为6000VAC/min,具有高柔韧性,最大导体电阻为39.50/km,耐油、耐极端温度、耐弯曲、耐高压尖峰。
功能详解为该硅橡胶线具有耐高温和高柔韧性,适用于LED电视、笔记本电脑、微波炉、复印机、扫描仪等设备。
应用信息为适用于高温和高柔性要求的场合。
封装信息为每卷500英尺。
此外,该产品符合RoHS标准,符合EU指令2011/65/EC,并且有SGS报告可供索取。
产品颜色包括黑色、白色、黄色、红色、蓝色、棕色、绿色、橙色、紫色、黄绿双色。
3239-20-1-0500-004-1-TS 价格&库存
很抱歉,暂时无法提供与“3239-20-1-0500-004-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+996.432221+129.43149
  • 2+948.258872+123.17402
  • 3+920.978063+119.63038
  • 1+2015.625601+261.81954
