3239-20-1-0500-002-1-TS
    CNC
    SILICON WIRE 20AWG WH 500'
3239-20-1-0500-002-1-TS 数据手册
P/N 3239-20-1-0500-0XX-1-TS (Conductor: Tinned strands) (Insulation: Silicone Rubber) UL3239 - Silicone Rubber Wire 150°C 3KV (20 AWG) CONSTRUCTION: Tinned Strands, copper conductor, 21/0.18mm strands. Overall Diameter = 1.85mm (+ +/0.10mm Insulation Thickness: 0.55mm CERTIFICATION & APPROVALS: DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: “AWM 3239 150℃ 3KVDC VW-1 20AWG E108485-S REIHSING CSA TYPE TV-3 150℃ 3KVDC 20AWG LL84687 FT1 SILICONE RUBBER” Passes UL VW-1 & CSA FT1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: APPLICATIONS: PACKAGING: ENVIRONMENTAL APPROVALS: Rated Temperature: 150℃ ~ -50℃ Rated Voltage: 3KV Insulation Potential Strength: 6000 VAC/min High flexibility: Soft silicone rubber material. Maximum Conductor Resistance: 39.5Ω/km Resistant to: Oil, extremes of hot & cold, flexing, high Voltage spikes. Silicone rubber wire, has high temperature resistance and high flexibility in confined spaces. Suitable for use in LED TVs, Laptops, Microwaves, Photocopiers, Scanners. 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 3239-20-1-0500-001-1-TS 3239-20-1-0500-002-1-TS 3239-20-1-0500-003-1-TS 3239-20-1-0500-004-1-TS 3239-20-1-0500-005-1-TS BLACK WHITE YELLOW RED BLUE 3239-20-1-0500-006-1-TS 3239-20-1-0500-007-1-TS BROWN GREEN 3239-20-1-0500-008-1-TS0 3239-20-1-0500-010-1-TS ORANGE VIOLET 3239-20-1-0500-011-1-TS GREEN + YELLOW
物料型号为3239-20-1-0500-0XX-1-TS,其中“XX”代表不同的颜色代码。
器件简介为UL3239硅橡胶线,具有150°C的耐温性和3KV的耐压性,适用于20AWG规格。
引脚分配未在文档中明确说明。
参数特性包括导体为镀锡铜丝,绝缘层为硅橡胶,额定温度范围为-50°C至150°C,额定电压为3KV,绝缘耐压强度为6000VAC/min,具有高柔韧性,最大导体电阻为39.50/km,耐油、耐极端温度、耐弯曲、耐高压尖峰。
功能详解为该硅橡胶线具有耐高温和高柔韧性,适用于LED电视、笔记本电脑、微波炉、复印机、扫描仪等设备。
应用信息为适用于高温和高柔性要求的场合。
封装信息为每卷500英尺。
此外,该产品符合RoHS标准,符合EU指令2011/65/EC,并且有SGS报告可供索取。
产品颜色包括黑色、白色、黄色、红色、蓝色、棕色、绿色、橙色、紫色、黄绿双色。
3239-20-1-0500-002-1-TS 价格&库存
很抱歉,暂时无法提供与“3239-20-1-0500-002-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+10.334261+1.34342
  • 5+9.243305+1.20160
  • 10+8.8086210+1.14510
  • 25+8.2652825+1.07446
  • 50+7.8681050+1.02283
  • 100+7.49021100+0.97371
库存:9235
  • 1+241.651081+31.41386
  • 2+230.080982+29.90979
  • 3+223.585673+29.06542
  • 5+215.578935+28.02457
  • 7+210.453507+27.35828
  • 10+205.1434710+26.66799
库存:15
  • 500+3.91475500+0.50891
  • 1000+3.723231000+0.48401
  • 1500+3.614831500+0.46992
  • 2500+3.482002500+0.45265
  • 3500+3.396673500+0.44156
  • 5000+3.308085000+0.43004
库存:9235
