3239-18-1-0500-002-1-TS
    CNC
3239-18-1-0500-002-1-TS 数据手册
P/N 3239-18-1-0500-0XX-1-TS (Conductor: Tinned strands) (Insulation: Silicone Rubber) UL3239 - Silicone Rubber Wire 150°C 3KV (18 AWG) CONSTRUCTION: Tinned Strands, copper conductor, 34/0.18mm strands. Overall Diameter = 2.10mm + 0.10mm – 0.03mm Insulation Thickness: 0.55mm CERTIFICATION & APPROVALS: DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: “AWM 3239 150℃ 3KV E108485-S 18AWG REIHSING CSA I A 150℃ 3KV LL84687 18AWG FT1 ” Passes UL VW-1 & CSA FT1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: APPLICATIONS: PACKAGING: ENVIRONMENTAL APPROVALS: Rated Temperature: 150℃ ~ -50℃ Rated Voltage: 3KV Insulation Potential Strength: 6000 VAC/min High flexibility: Soft silicone rubber material. Maximum Conductor Resistance: 24.4Ω/km Resistant to: Oil, extremes of hot & cold, flexing, high Voltage spikes. Silicone rubber wire, has high temperature resistance and high flexibility in confined spaces. Suitable for use in LED TVs, Laptops, Microwaves, Photocopiers, Scanners. 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC Current SGS reports for this wire are available upon request. P/N's & COLORS 3239-18-1-0500-001-1-TS 3239-18-1-0500-002-1-TS 3239-18-1-0500-003-1-TS 3239-18-1-0500-004-1-TS 3239-18-1-0500-005-1-TS BLACK WHITE YELLOW RED BLUE 3239-18-1-0500-006-1-TS 3239-18-1-0500-007-1-TS 3239-18-1-0500-008-1-TS 3239-18-1-0500-010-1-TS 3239-18-1-0500-011-1-TS BROWN GREEN ORANGE VIOLET GREEN + YELLOW
3239-18-1-0500-002-1-TS 价格&库存
很抱歉,暂时无法提供与“3239-18-1-0500-002-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+13.833561+1.79024
  • 5+12.353455+1.59870
  • 10+11.7696910+1.52315
  • 25+11.0370825+1.42834
  • 50+10.5092550+1.36004
  • 100+10.00217100+1.29441
  • 500+5.22060500+0.67562
  • 1000+4.964341000+0.64245
  • 1500+4.819291500+0.62368
  • 2500+4.641512500+0.60067
  • 3500+4.527293500+0.58589
  • 5000+4.408705000+0.57055
  • 1+142.855081+18.48729
  • 2+136.007992+17.60119
  • 3+132.170843+17.10461
  • 5+127.476605+16.49712
  • 7+124.456907+16.10633
  • 10+121.3350310+15.70232
    • 1+4071.088701+526.85136
    • 2+4026.133862+521.03363
    • 4+2415.599184+312.60968
    • 6+1880.958216+243.42024
    • 8+1843.386728+238.55801
    库存:16
