Silicone Cover Stranded-Core Wire - 25ft
26AWG - Gray
PRODUCT ID: 2519
DESCRIPTION
Silicone-sheathing wire is super-flexible and soft, and its also strong! Able to
handle up to 200°C and up to 600V, it will do when PVC covered wire wimps out.
We like this wire for being extremely supple and flexible, so it is great for
wearables or projects where the wire-harness has to be able to deal with a lot of
bending.
Comes with one 25ft spool of gray wire. The wire is 26AWG stranded with an outer
diameter of 1.5mm.
https://www.adafruit.com/products/2519
3/30/2016
Technical Details
Length: 25 feet / 7.6m
Outer Diameter: 1.5mm / 0.06"
Nominal Voltage: 600V
Temperature Range: -60°C ~ 200°C
OD Tolerance: ±0.1mm
Resistance: 123 Ω/Km
Current Handling Capability: ~3.5A (depends on length!)
很抱歉,暂时无法提供与“2519”相匹配的价格&库存,您可以联系我们找货
