2981
2981
    ADAFRUIT
2981 数据手册
Stranded-Core Wire Spool - 25ft - 22AWG - Violet PRODUCT ID: 2981 Description This wire is flexible, strong, and super easy to solder, too! Stranded core wire is best used for wiring jigs where theres bending or movement expected. Works well with terminal blocks as well. It's not great for use with breadboards (without tinning) For prototyping with breadboards, perfboards, and terminal blocks check out our solid-core wires. &RPHVZLWKRQHIWVSRRO¬RIv violet wire. The wire is 22AWG stranded with an outer diameter of 1.6mm. Technical Details Length: 25 feet / 7.6m Outer Diameter: 1.6mm / 0.06" Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2981”相匹配的价格&库存,您可以联系我们找货
