3135-22-1-0500-004-1-TS 数据手册
P/N 3135-22-1-0500-0XX-1-TS
(Conductor: Tinned strands)
(Insulation: Silicone Rubber)
UL3135 - Silicone Rubber Wire 200℃ 600V (22 AWG)
CONSTRUCTION:
CERTIFICATION & APPROVALS:
Tinned Strands, copper conductor, 17/0.160mm strands.
Overall Diameter = 2.30mm ± 0.15mm
Insulation Thickness: 0.76mm
DUAL-RATED AWM: Can be used in USA and Canada
UL Subject 758 UL FILE NO:E108485
CSA Standard CSA FILE NO:LL84687
Printed Markings:
“AWM 3135 200℃ 600V E108485-S 22AWG REIHSING CSA
I A 200℃ 600V LL84687 22AWG FT1 ”
Passes UL VW-1 & CSA FT1 Vertical Flame Test.
PHYSICAL
ELECTRICAL PROPERTIES:
APPLICATIONS:
PACKAGING:
ENVIRONMENTAL APPROVALS:
Rated Temperature: 200℃ ~ -30℃
Rated Voltage: 600V
Insulation Potential Strength: 2000 VAC/min
High flexibility: Soft silicone rubber material.
Maximum Conductor Resistance: 62.5Ω/km
Resistant to: Oil, extremes of hot & cold, flexing.
Silicone rubber wire, has high temperature resistance and
high flexibility in confined spaces. Suitable for use in whole
sealed cooking appliances, lighting equipment, internal
combustion engine and mercury switches.
500ft per reel.
Conforms to all current RoHS directives as laid out in EU
Directive 2011/65/EC.
Current SGS reports for this wire are available upon
request.
P/N's & COLORS
3135-22-1-0500-001-1-TS
3135-22-1-0500-002-1-TS
3135-22-1-0500-003-1-TS
3135-22-1-0500-005-1-TS
BLACK
WHITE
YELLOW
RED
BLUE
3135-22-1-0500-006-1-TS
3135-22-1-0500-007-1-TS
3135-22-1-0500-008-1-TS
3135-22-1-0500-010-1-TS
3135-22-1-0500-011-1-TS
BROWN
GREEN
ORANGE
VIOLET
GREEN + YELLOW
3135-22-1-0500-004-1-TS 价格&库存
很抱歉,暂时无法提供与“3135-22-1-0500-004-1-TS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+161.863461+20.96698
