3132-20-1-0500-003-1-TS
    CNC
    SILICONWIRE20AWGYL500'
3132-20-1-0500-003-1-TS 数据手册
P/N 3132-20-1-2000-0XX-1-TD (Conductor: Tinned Solid) (Insulation: Silicone Rubber) UL3132 Silicone Wire 150°C 300V (20AWG) CONSTRUCTION: Tinned Solid copper conductor, 1/0.813mm strands. Overall Diameter=1.70+/-0.10mm Insulation Thickness: 0.39mm CERTIFICATION & APPROVALS: DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: AWM 3132 150°C 300V E108485-S ( )AWG REI HSING CSA I A 150° 300V LL84687 ()AWG FT2 HF Rated Temperature: 150℃ ~ -30℃ PHYSICAL & ELECTRICAL PROPERTIES: Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min. Flexibility: XLPE Insulation Maximum Conductor Resistance: 36.0 ohm/km Resistant to: Oil, hot & cold, lighter, flexing. APPLICATIONS: Silicone Rubber Wire, Tinned Solid ,pass FT2 flame test Suitable for internal wires of electronic & electrical equipment. PACKAGING: ENVIRONMENTAL APPROVALS: 2000ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 3132-20-1-2000-001-1-TD BLACK 3132-20-1-2000-006-1-TD BROWN 3132-20-1-2000-002-1-TD WHITE 3132-20-1-2000-007-1-TD GREEN 3132-20-1-2000-003-1-TD YELLOW 3132-20-1-2000-008-1-TD ORANGE 3132-20-1-2000-004-1-TD RED 3132-20-1-2000-010-1-TD VIOLET 3132-20-1-2000-005-1-TD BLUE 3132-20-1-2000-011-1-TD GREEN + YELLOW
3132-20-1-0500-003-1-TS 价格&库存
很抱歉,暂时无法提供与“3132-20-1-0500-003-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+74.310201+9.62577
  • 2+70.822412+9.17398
  • 3+68.810083+8.91332
  • 5+66.385345+8.59923
  • 7+64.826587+8.39731
库存:6
  • 1+8.075611+1.04608
  • 5+7.260585+0.94050
  • 10+6.9160110+0.89587
  • 25+6.4869525+0.84029
  • 50+6.1767250+0.80011
  • 100+5.88005100+0.76168
库存:6029
    • 1+127.96920
    • 500+2.41772500+0.31318
    • 1000+2.299911000+0.29792
    • 1500+2.233301500+0.28929
    • 2500+2.151662500+0.27872
    • 3500+2.099213500+0.27193
    • 5000+2.044785000+0.26487
    库存:6029
    • 1+133.293321+17.26615
    • 2+126.941702+16.44339
    • 3+123.345473+15.97756
    • 5+118.958185+15.40925
    • 7+116.145407+15.04489
    • 10+113.2241210+14.66649
    库存:10
    • 1+303.885721+39.36383
    • 3+228.238723+29.56490
    • 5+216.684565+28.06823
    • 10+206.4302510+26.73994
    • 25+193.6109725+25.07939
    • 50+184.6350850+23.91670
    • 100+175.66015100+22.75414
    • 500+166.68407500+21.59142
    库存:2
