3132-20-1-0500-007-1-TS
    CNC
    SILICONWIRE20AWGGN500'
3132-20-1-0500-007-1-TS 数据手册
P/N 3132-20-1-2000-0XX-1-TD (Conductor: Tinned Solid) (Insulation: Silicone Rubber) UL3132 Silicone Wire 150°C 300V (20AWG) CONSTRUCTION: Tinned Solid copper conductor, 1/0.813mm strands. Overall Diameter=1.70+/-0.10mm Insulation Thickness: 0.39mm CERTIFICATION & APPROVALS: DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: AWM 3132 150°C 300V E108485-S ( )AWG REI HSING CSA I A 150° 300V LL84687 ()AWG FT2 HF Rated Temperature: 150℃ ~ -30℃ PHYSICAL & ELECTRICAL PROPERTIES: Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min. Flexibility: XLPE Insulation Maximum Conductor Resistance: 36.0 ohm/km Resistant to: Oil, hot & cold, lighter, flexing. APPLICATIONS: Silicone Rubber Wire, Tinned Solid ,pass FT2 flame test Suitable for internal wires of electronic & electrical equipment. PACKAGING: ENVIRONMENTAL APPROVALS: 2000ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 3132-20-1-2000-001-1-TD BLACK 3132-20-1-2000-006-1-TD BROWN 3132-20-1-2000-002-1-TD WHITE 3132-20-1-2000-007-1-TD GREEN 3132-20-1-2000-003-1-TD YELLOW 3132-20-1-2000-008-1-TD ORANGE 3132-20-1-2000-004-1-TD RED 3132-20-1-2000-010-1-TD VIOLET 3132-20-1-2000-005-1-TD BLUE 3132-20-1-2000-011-1-TD GREEN + YELLOW
3132-20-1-0500-007-1-TS 价格&库存
很抱歉,暂时无法提供与“3132-20-1-0500-007-1-TS”相匹配的价格&库存,您可以联系我们找货
    • 1+497.36160
    • 1+228.839571+29.64273
    • 2+217.864232+28.22104
    • 3+211.692153+27.42154
    • 5+204.143455+26.44372
    • 7+199.288597+25.81485
    • 10+194.2443110+25.16144
    库存:9
    • 1+79.035251+10.23783
    • 2+75.222142+9.74390
    • 4+71.478374+9.25895
    • 10+66.9559710+8.67314
    • 20+63.5716420+8.23475
    • 40+60.5635640+7.84510
    • 100+56.80245100+7.35791
    • 200+54.16917200+7.01681
    • 400+51.53549400+6.67565
    库存:7
    • 1+1239.221421+160.52252
    • 2+1179.102382+152.73500
    • 3+1145.090203+148.32923
    • 5+1103.419465+142.93141
    • 7+1076.652937+139.46421
    • 10+1048.8851510+135.86731
    库存:13
    • 1+133.293321+17.26615
    • 2+126.941702+16.44339
    库存:2
