3135-22-1-0500-002-1-TS
    CNC
    HOOK-UP STRND 22AWG WHITE 500'
3135-22-1-0500-002-1-TS 数据手册
P/N 3135-22-1-0500-0XX-1-TS (Conductor: Tinned strands) (Insulation: Silicone Rubber) UL3135 - Silicone Rubber Wire 200℃ 600V (22 AWG) CONSTRUCTION: CERTIFICATION & APPROVALS: Tinned Strands, copper conductor, 17/0.160mm strands. Overall Diameter = 2.30mm ± 0.15mm Insulation Thickness: 0.76mm DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: “AWM 3135 200℃ 600V E108485-S 22AWG REIHSING CSA I A 200℃ 600V LL84687 22AWG FT1 ” Passes UL VW-1 & CSA FT1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: APPLICATIONS: PACKAGING: ENVIRONMENTAL APPROVALS: Rated Temperature: 200℃ ~ -30℃ Rated Voltage: 600V Insulation Potential Strength: 2000 VAC/min High flexibility: Soft silicone rubber material. Maximum Conductor Resistance: 62.5Ω/km Resistant to: Oil, extremes of hot & cold, flexing. Silicone rubber wire, has high temperature resistance and high flexibility in confined spaces. Suitable for use in whole sealed cooking appliances, lighting equipment, internal combustion engine and mercury switches. 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 3135-22-1-0500-001-1-TS 3135-22-1-0500-002-1-TS 3135-22-1-0500-003-1-TS 3135-22-1-0500-004-1-TS 3135-22-1-0500-005-1-TS BLACK WHITE YELLOW RED BLUE 3135-22-1-0500-006-1-TS 3135-22-1-0500-007-1-TS 3135-22-1-0500-008-1-TS 3135-22-1-0500-010-1-TS 3135-22-1-0500-011-1-TS BROWN GREEN ORANGE VIOLET GREEN + YELLOW
3135-22-1-0500-002-1-TS 价格&库存
很抱歉,暂时无法提供与“3135-22-1-0500-002-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+10.249001+1.32761
  • 5+9.199575+1.19167
  • 10+8.7644410+1.13530
  • 25+8.2201025+1.06479
  • 50+7.8280650+1.01401
  • 100+7.45255100+0.96537
库存:11530
  • 500+3.55731500+0.46080
  • 1000+3.383301000+0.43826
  • 1500+3.284831500+0.42550
  • 2500+3.164172500+0.40987
  • 3500+3.086643500+0.39983
  • 5000+3.006165000+0.38941
库存:11530
  • 1+242.424421+31.40244
  • 2+230.815652+29.89870
  • 3+224.283383+29.05255
  • 5+216.244165+28.01119
  • 7+211.101537+27.34504
库存:6
  • 1+161.863461+20.96698
