1332-22-1-0500-007-1-TS
    CNC
    FEP TEFWIRE GN 100'
1332-22-1-0500-007-1-TS 数据手册
P/N 1332-22-1-0500-0XX-1-TS (Conductor: Tinned strands) (Insulation: FEP Material) UL1332 - FEP Insulated Hook-Up Wire 200°C 300V (22 AWG) CONSTRUCTION: CERTIFICATION & APPROVALS: Tinned Strands, copper conductor, 7/0.254 mm strands. Overall Diameter = 1.45 mm ± 0.10 mm Insulation Thickness: 0.33 mm UL RATED AWM: Can be used in the USA. UL Subject 758 UL FILE NO:E108485 Printed Markings: “AWM 1332 200℃ 300V E108485 22AWG REIHSING VW-1 ” Passes UL VW-1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: APPLICATIONS: PACKAGING: ENVIRONMENTAL APPROVALS: Rated Temperature: 200℃ ~ -80℃ Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min Flexibility: hard FEP material, is slightly more rigid than PVC insulation material. Maximum Conductor Resistance: 62.5Ω/km Resistant to: Chemical solvents, abrasion, cutting, extremes of hot & cold, flexing, shock, compression. FEP wire, has good resistance to extremes of temp., compression and repeat flexing. Suitable for use in whole sealed cooking appliances, auto headlamps, internal combustion engine and mercury switches, when shock or sharp casing edges are a “wear and tear” factor. 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS report for this wire are available upon request. P/N's & COLORS 1332-22-1-0500-001-1-TS 1332-22-1-0500-002-1-TS 1332-22-1-0500-003-1-TS 1332-22-1-0500-004-1-TS 1332-22-1-0500-005-1-TS BLACK WHITE YELLOW RED BLUE 1332-22-1-0500-007-1-TS 1332-22-1-0500-008-1-TS 1332-22-1-0500-010-1-TS 1332-22-1-0500-012-1-TS GREEN ORANGE VIOLET GRAY 1332-22-1-0500-006-1-TS BROWN
物料型号:P/N 1332-22-1-0500-0XX-1-TS
器件简介:这是一种符合RoHS标准的100 UL1332 - FEP绝缘钩编线,导体为镀锡绞合铜线,绝缘材料为FEP,额定温度200°C,额定电压300V。
引脚分配:文档未提及引脚分配
参数特性: - 导体规格:7/0.254 mm,外径1.45 mm ± 0.10 mm - 绝缘厚度:0.33 mm - 额定温度:200°C至-80°C - 额定电压:300V - 绝缘耐压强度:2000 VAC/min - 导体电阻:最大62.5Ω/km - 抗性:耐化学溶剂、磨损、切割、极端温度、弯曲、冲击、压缩
功能详解:FEP电线具有良好的耐极端温度、压缩和重复弯曲性,适用于密封烹饪器具、汽车前灯、内燃机和水银开关等。
应用信息:适用于可能存在磨损因素的场合,如密封烹饪器具、汽车前灯、内燃机和水银开关。
封装信息:每卷500英尺。
环境批准:符合EU Directive 2011/65/EC的RoHS指令,可应要求提供当前的SGS报告。
1332-22-1-0500-007-1-TS 价格&库存
很抱歉,暂时无法提供与“1332-22-1-0500-007-1-TS”相匹配的价格&库存,您可以联系我们找货
    • 1+5.34737
    • 26+4.87893
    • 51+4.32209
    • 500+3.74493
    库存:3571
