3239-18-1-0500-010-1-TS 数据手册
P/N 3239-18-1-0500-0XX-1-TS
(Conductor: Tinned strands)
(Insulation: Silicone Rubber)
UL3239 - Silicone Rubber Wire 150°C 3KV (18 AWG)
CONSTRUCTION:
Tinned Strands, copper conductor, 34/0.18mm strands.
Overall Diameter = 2.10mm + 0.10mm – 0.03mm
Insulation Thickness: 0.55mm
CERTIFICATION & APPROVALS:
DUAL-RATED AWM: Can be used in USA and Canada
UL Subject 758 UL FILE NO:E108485
CSA Standard CSA FILE NO:LL84687
Printed Markings:
“AWM 3239 150℃ 3KV E108485-S 18AWG REIHSING CSA I
A 150℃ 3KV LL84687 18AWG FT1 ”
Passes UL VW-1 & CSA FT1 Vertical Flame Test.
PHYSICAL
ELECTRICAL PROPERTIES:
APPLICATIONS:
PACKAGING:
ENVIRONMENTAL APPROVALS:
Rated Temperature: 150℃ ~ -50℃
Rated Voltage: 3KV
Insulation Potential Strength: 6000 VAC/min
High flexibility: Soft silicone rubber material.
Maximum Conductor Resistance: 24.4Ω/km
Resistant to: Oil, extremes of hot & cold, flexing, high
Voltage spikes.
Silicone rubber wire, has high temperature resistance and
high flexibility in confined spaces. Suitable for use in LED
TVs, Laptops, Microwaves, Photocopiers, Scanners.
500ft per reel.
Conforms to all current RoHS directives as laid out in EU
Directive 2011/65/EC
Current SGS reports for this wire are available upon
request.
P/N's & COLORS
3239-18-1-0500-001-1-TS
3239-18-1-0500-002-1-TS
3239-18-1-0500-003-1-TS
3239-18-1-0500-004-1-TS
3239-18-1-0500-005-1-TS
BLACK
WHITE
YELLOW
RED
BLUE
3239-18-1-0500-006-1-TS
3239-18-1-0500-007-1-TS
3239-18-1-0500-008-1-TS
3239-18-1-0500-011-1-TS
BROWN
GREEN
ORANGE
VIOLET
GREEN + YELLOW
3239-18-1-0500-010-1-TS 价格&库存
很抱歉,暂时无法提供与“3239-18-1-0500-010-1-TS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+132.745901+17.04749
