1332-20-1-0500-007-1-TS
    CNC
    FEPTEFWIREGN500'
1332-20-1-0500-007-1-TS 数据手册
P/N 1332-20-1-0500-0XX-1-TS (Conductor: Tinned strands) (Insulation: FEP Material) UL1332 - FEP Insulated Hook-Up Wire 200°C 300V (20 AWG) CONSTRUCTION: CERTIFICATION & APPROVALS: Tinned Strands, copper conductor, 7/0.320 mm strands. Overall Diameter = 1.65 mm ± 0.10 mm Insulation Thickness: 0.33 mm UL RATED AWM: Can be used in the USA. UL Subject 758 UL FILE NO:E108485 Printed Markings: “AWM 1332 200℃ 300V E108485 20AWG REIHSING VW-1 ” Passes UL VW-1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: APPLICATIONS: PACKAGING: ENVIRONMENTAL APPROVALS: Rated Temperature: 200℃ ~ -80℃ Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min Flexibility: hard FEP material, is slightly more rigid than PVC insulation material. Maximum Conductor Resistance: 39.5Ω/km Resistant to: Chemical solvents, abrasion, cutting, extremes of hot & cold, flexing, shock, compression. FEP wire, has good resistance to extremes of temp., compression and repeat flexing. Suitable for use in whole sealed cooking appliances, auto headlamps, internal combustion engine and mercury switches, when shock or sharp casing edges are a “wear and tear” factor. 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC, Current SGS reports for this wire are available upon request. P/N's & COLORS 1332-20-1-0500-001-1-TS 1332-20-1-0500-002-1-TS 1332-20-1-0500-003-1-TS 1332-20-1-0500-004-1-TS 1332-20-1-0500-005-1-TS BLACK WHITE YELLOW RED BLUE 1332-20-1-0500-007-1-TS 1332-20-1-0500-008-1-TS 1332-20-1-0500-010-1-TS 1332-20-1-0500-012-1-TS GREEN ORANGE VIOLET GRAY 1332-20-1-0500-006-1-TS BROWN
物料型号为1332-20-1-0500-0XX-1-TS,其中“0XX”代表不同的颜色代码。
器件简介为UL1332 FEP绝缘绞合线,具有200°C耐温和300V耐压的20 AWG规格。
引脚分配未在文档中明确说明,但通常绞合线用于连接电路中的不同点。
参数特性包括: - 导体:镀锡铜丝,7/0.320 mm线径 - 绝缘:FEP材料,绝缘厚度0.33 mm - 额定温度:-80°C至200°C - 额定电压:300V - 绝缘耐压:2000 VAC/min - 导体最大电阻:39.5Ω/km - 耐化学溶剂、耐磨损、耐切割、耐极端温度、耐弯曲、耐冲击、耐压缩
功能详解为FEP线具有良好的耐温、耐压缩和耐重复弯曲特性,适用于密封烹饪电器、汽车前灯、内燃机和水银开关等环境。
应用信息指出,该线材适用于需要耐极端温度、耐压缩和耐重复弯曲的应用场合,如密封烹饪电器、汽车前灯、内燃机和水银开关。
封装信息为每卷500英尺。
此外,该产品符合RoHS标准,UL认证文件号为E108485,并通过UL VW-1垂直火焰测试。
产品颜色包括黑色、白色、黄色、红色、蓝色、棕色、绿色、橙色、紫色和灰色。
1332-20-1-0500-007-1-TS 价格&库存
很抱歉,暂时无法提供与“1332-20-1-0500-007-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+181.209931+23.47303
  • 1+338.912941+43.90108
  • 2+322.668582+41.79687
  • 3+313.470923+40.60545
  • 5+302.249555+39.15189
库存:5
