1330-20-1-0500-001-1-TS
    CNC
1330-20-1-0500-001-1-TS 数据手册
P/N 1330-20-1-0500-0XX-1-TS (Conductor: Tinned strands) (Insulation: FEP Material) UL1330 - FEP Insulated Hook-Up Wire 200°C 600V (20 AWG) CONSTRUCTION: CERTIFICATION & APPROVALS: Tinned Strands, copper conductor, 7/0.32 mm strands. Overall Diameter = 2.05 mm ± 0.10 mm Insulation Thickness: 0.51 mm UL RATED AWM: Can be used in the USA. UL Subject 758 UL FILE NO:E108485 Printed Markings: “AWM 1330 200℃ 600V E108485 20AWG REIHSING VW-1 ” Passes UL VW-1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: APPLICATIONS: PACKAGING: ENVIRONMENTAL APPROVALS: Rated Temperature: 200℃ ~ -80℃ Rated Voltage: 600V Insulation Potential Strength: 2000 VAC/min Flexibility: hard FEP material, is slightly more rigid than PVC insulation material. Maximum Conductor Resistance: 39.5Ω/km Resistant to: Chemical solvents, abrasion, cutting, extremes of hot & cold, flexing, shock, compression. FEP wire, has good resistance to extremes of temp., compression and repeat flexing. Suitable for use in whole sealed cooking appliances, auto headlamps, internal combustion engine and mercury switches, when shock or sharp casing edges are a “wear and tear” factor. 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 1330-20-1-0500-001-1-TS 1330-20-1-0500-002-1-TS 1330-20-1-0500-003-1-TS 1330-20-1-0500-004-1-TS 1330-20-1-0500-005-1-TS BLACK WHITE YELLOW RED BLUE 1330-20-1-0500-007-1-TS 1330-20-1-0500-008-1-TS 1330-20-1-0500-010-1-TS 1330-20-1-0500-012-1-TS GREEN ORANGE VIOLET GRAY 1330-20-1-0500-006-1-TS BROWN
物料型号为1330-20-1-0500-0XX-1-TS,其中“0XX”代表不同的颜色代码。
器件简介为UL1330 FEP绝缘套管线,具有200°C耐温和600V耐压的特性,适用于20 AWG规格的导线。
引脚分配未在文档中明确说明。
参数特性包括导体为镀锡绞合铜线,绝缘材料为FEP,整体直径为2.05mm±0.10mm,绝缘厚度为0.51mm,额定温度范围为-80°C至200°C,额定电压为600V,绝缘耐压强度为2000V AC/min,导体最大电阻为39.50Ω/km。
功能详解指出该线材具有良好的耐化学溶剂、耐磨损、耐切割、耐极端温度、耐弯曲、耐冲击和耐压缩的特性。
应用信息表明,该线材适用于密封烹饪电器、汽车前灯、内燃机和水银开关等场合,特别是在存在冲击或锋利边缘导致磨损的环境中。
封装信息为每卷500英尺。
此外,该产品符合RoHS标准,并且有UL认证,文件编号为E108485。
产品颜色包括黑色、白色、黄色、红色、蓝色、棕色、绿色、橙色、紫色和灰色。
1330-20-1-0500-001-1-TS 价格&库存
很抱歉,暂时无法提供与“1330-20-1-0500-001-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+9.777901+1.26595
  • 5+8.762875+1.13453
  • 10+8.3458010+1.08053
  • 25+7.8240225+1.01298
  • 50+7.4512150+0.96471
  • 100+7.09276100+0.91830
库存:3465
  • 1+259.714661+33.62528
  • 1+798.057851+103.32462
  • 500+3.30344500+0.42770
  • 1000+3.142051000+0.40680
  • 1500+3.050661500+0.39497
  • 2500+2.938662500+0.38047
库存:3465
