2518
2518
    ADAFRUIT
2518 数据手册
Silicone Cover Stranded-Core Wire - 25ft 26AWG - White PRODUCT ID: 2518 DESCRIPTION - Silicone-sheathing wire is super-flexible and soft, and its also strong! Able to handle up to 200°C and up to 600V, it will do when PVC covered wire wimps out. We like this wire for being extremely supple and flexible, so it is great for wearables or projects where the wire-harness has to be able to deal with a lot of bending. Comes with one 25ft spool of white wire. The wire is 26AWG stranded with an outer diameter of 1.5mm. https://www.adafruit.com/products/2518 3/30/2016 Technical Details Length: 25 feet / 7.6m Outer Diameter: 1.5mm / 0.06" Nominal Voltage: 600V Temperature Range: -60°C ~ 200°C OD Tolerance: ±0.1mm Resistance: 123 Ω/Km Current Handling Capability: ~3.5A (depends on length!)
很抱歉,暂时无法提供与“2518”相匹配的价格&库存,您可以联系我们找货
