3132-20-1-0500-011-1-TS
    CNC
    SILICON WIRE 20AWG GN/YL 25'
3132-20-1-0500-011-1-TS 数据手册
P/N 3132-20-1-2000-0XX-1-TD (Conductor: Tinned Solid) (Insulation: Silicone Rubber) UL3132 Silicone Wire 150°C 300V (20AWG) CONSTRUCTION: Tinned Solid copper conductor, 1/0.813mm strands. Overall Diameter=1.70+/-0.10mm Insulation Thickness: 0.39mm CERTIFICATION & APPROVALS: DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: AWM 3132 150°C 300V E108485-S ( )AWG REI HSING CSA I A 150° 300V LL84687 ()AWG FT2 HF Rated Temperature: 150℃ ~ -30℃ PHYSICAL & ELECTRICAL PROPERTIES: Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min. Flexibility: XLPE Insulation Maximum Conductor Resistance: 36.0 ohm/km Resistant to: Oil, hot & cold, lighter, flexing. APPLICATIONS: Silicone Rubber Wire, Tinned Solid ,pass FT2 flame test Suitable for internal wires of electronic & electrical equipment. PACKAGING: ENVIRONMENTAL APPROVALS: 2000ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 3132-20-1-2000-001-1-TD BLACK 3132-20-1-2000-006-1-TD BROWN 3132-20-1-2000-002-1-TD WHITE 3132-20-1-2000-007-1-TD GREEN 3132-20-1-2000-003-1-TD YELLOW 3132-20-1-2000-008-1-TD ORANGE 3132-20-1-2000-004-1-TD RED 3132-20-1-2000-010-1-TD VIOLET 3132-20-1-2000-005-1-TD BLUE 3132-20-1-2000-011-1-TD GREEN + YELLOW
3132-20-1-0500-011-1-TS 价格&库存
很抱歉,暂时无法提供与“3132-20-1-0500-011-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+69.899781+9.05447
  • 1+216.698711+28.07007
  • 3+202.279193+26.20223
  • 5+193.398905+25.05193
  • 10+183.3960310+23.75620
  • 25+172.2806125+22.31637
  • 50+163.3911350+21.16487
  • 100+155.61004100+20.15695
  • 500+144.49380500+18.71700
库存:1
  • 500+2.43779500+0.31578
  • 1000+2.319111000+0.30041
  • 1500+2.251891500+0.29170
  • 2500+2.169572500+0.28104
  • 3500+2.116713500+0.27419
  • 5000+2.061805000+0.26708
库存:7056
  • 1+9.439441+1.22274
  • 5+8.475235+1.09784
  • 10+8.0667210+1.04493
  • 25+7.5677625+0.98029
  • 50+7.2046950+0.93326
  • 100+6.85804100+0.88836
库存:7056
  • 1+550.822061+71.35072
