1672-24-1-0500-010-1-TS
    CNC
1672-24-1-0500-010-1-TS 数据手册
P/N 1672-24-1-0500-0XX-1-TS UL1672 PVC Wire 105°C 300V (24AWG) Tinned Strands, copper conductor, 11/0.16mm strands. CONSTRUCTION: CERTIFICATION & APPROVALS: Overall Diameter=2.40+/-0.15mm Insulation Thickness: 0.40mm Jacket Thickness: 0.50mm DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: AWG 1672 VW-1  105°C 300V E108485-S ( ) AWG REI HSING CSA AWM IA/B 105°C 300V LL84687  ( ) AWG FT1-F-LF Passes UL VW-1 & CSA FT1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: Rated Temperature: 105℃ ~ -10℃ Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min. Flexibility: PVC Insulation Maximum Conductor Resistance: 88.6ohm/km Resistant to: Oil, hot & cold, lighter, flexing. APPLICATIONS: PACKAGING: ENVIRONMENTAL APPROVALS: Suitable for Internal wiring of electric equipment 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 1672-24-1-0500-001-1-TS BLACK 1672-24-1-0500-006-1-TS BROWN 1672-24-1-0500-002-1-TS WHITE 1672-24-1-0500-007-1-TS GREEN 1672-24-1-0500-003-1-TS YELLOW 1672-24-1-0500-008-1-TS ORANGE 1672-24-1-0500-004-1-TS RED 1672-24-1-0500-010-1-TS VIOLET 1672-24-1-0500-005-1-TS BLUE 1672-24-1-0500-011-1-TS GREEN + YELLOW
1672-24-1-0500-010-1-TS 价格&库存
很抱歉,暂时无法提供与“1672-24-1-0500-010-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+59.428821+7.71084
  • 2+56.394022+7.31708
  • 4+53.899634+6.99344
  • 10+50.3127110+6.52804
  • 20+48.0983720+6.24073
  • 40+45.6093040+5.91777
  • 100+42.84582100+5.55921
  • 200+40.63457200+5.27231
  • 400+38.69981400+5.02127
库存:21
  • 500+1.41718500+0.18388
  • 1000+1.348601000+0.17498
  • 1500+1.309741500+0.16994
  • 2500+1.262202500+0.16377
  • 3500+1.231653500+0.15981
  • 5000+1.199935000+0.15569
库存:4500
  • 1+6.154791+0.79858
  • 5+5.526535+0.71707
  • 10+5.2720410+0.68405
  • 25+4.9425725+0.64130
  • 50+4.7070350+0.61074
  • 100+4.48235100+0.58158
库存:4500
  • 1+174.932191+22.69731
  • 3+163.453203+21.20792
  • 5+155.505225+20.17668
  • 10+148.4389310+19.25983
  • 25+138.7207625+17.99891
  • 50+132.5350950+17.19632
  • 100+125.46657100+16.27919
  • 500+114.86400500+14.90351
库存:3
  • 1+101.372931+13.15306
  • 2+96.613092+12.53547
库存:2
