1672-20-1-0500-005-1-TS
    CNC
1672-20-1-0500-005-1-TS 数据手册
P/N 1672-20-1-0500-0XX-1-TS UL1672 PVC Wire 105°C 300V (20AWG) Tinned Strands, copper conductor, 21/0.18mm strands. CONSTRUCTION: CERTIFICATION & APPROVALS: Overall Diameter=2.80+/-0.15mm Insulation Thickness: 0.40mm Jacket Thickness: 0.50mm DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: AWG 1672 VW-1  105°C 300V E108485-S ( ) AWG REI HSING CSA AWM IA/B 105°C 300V LL84687  ( ) AWG FT1-F-LF Passes UL VW-1 & CSA FT1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: Rated Temperature: 105℃ ~ -10℃ Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min. Flexibility: PVC Insulation Maximum Conductor Resistance: 39.5ohm/km Resistant to: Oil, hot & cold, lighter, flexing. APPLICATIONS: PACKAGING: ENVIRONMENTAL APPROVALS: Suitable for Internal wiring of electric equipment 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 1672-20-1-0500-001-1-TS BLACK 1672-20-1-0500-006-1-TS BROWN 1672-20-1-0500-002-1-TS WHITE 1672-20-1-0500-007-1-TS GREEN 1672-20-1-0500-003-1-TS YELLOW 1672-20-1-0500-008-1-TS ORANGE 1672-20-1-0500-004-1-TS RED 1672-20-1-0500-010-1-TS VIOLET 1672-20-1-0500-005-1-TS BLUE 1672-20-1-0500-011-1-TS GREEN + YELLOW
1672-20-1-0500-005-1-TS 价格&库存
很抱歉,暂时无法提供与“1672-20-1-0500-005-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+125.917531+16.33770
  • 2+119.938442+15.56192
  • 3+116.589523+15.12740
  • 5+112.438765+14.58884
  • 7+109.780617+14.24395
库存:6
  • 1+230.513381+29.90892
    • 1+430.14240
