1672-18-1-0500-006-1-TS
    CNC
1672-18-1-0500-006-1-TS 数据手册
P/N 1672-18-1-0500-0XX-1-TS UL1672 PVC Wire 105°C 300V (18AWG) Tinned Strands, copper conductor, 34/0.18mm strands. CONSTRUCTION: CERTIFICATION & APPROVALS: Overall Diameter=3.10+/-0.15mm Insulation Thickness: 0.40mm Jacket Thickness: 0.50mm DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: AWG 1672 VW-1  105°C 300V E108485-S ( ) AWG REI HSING CSA AWM IA/B 105°C 300V LL84687  ( ) AWG FT1-F-LF Passes UL VW-1 & CSA FT1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: Rated Temperature: 105℃ ~ -10℃ Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min. Flexibility: PVC Insulation Maximum Conductor Resistance: 24.4ohm/km Resistant to: Oil, hot & cold, lighter, flexing. APPLICATIONS: Suitable for internal wires of electronic & electrical equipment. PACKAGING: ENVIRONMENTAL APPROVALS: 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 1672-18-1-0500-001-1-TS BLACK 1672-18-1-0500-006-1-TS BROWN 1672-18-1-0500-002-1-TS WHITE 1672-18-1-0500-007-1-TS GREEN 1672-18-1-0500-003-1-TS YELLOW 1672-18-1-0500-008-1-TS ORANGE 1672-18-1-0500-004-1-TS RED 1672-18-1-0500-010-1-TS VIOLET 1672-18-1-0500-005-1-TS BLUE 1672-18-1-0500-011-1-TS GREEN + YELLOW
1672-18-1-0500-006-1-TS 价格&库存
很抱歉,暂时无法提供与“1672-18-1-0500-006-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 500+2.84141500+0.36729
  • 1000+2.702701000+0.34936
  • 1500+2.624241500+0.33921
  • 2500+2.528122500+0.32679
  • 3500+2.466373500+0.31881
  • 5000+2.402275000+0.31052
库存:658
  • 1+286.319481+37.00983
  • 1+9.172111+1.18560
  • 5+8.174825+1.05669
  • 10+7.7936210+1.00741
  • 25+7.3069425+0.94450
  • 50+6.9582050+0.89943
  • 100+6.62389100+0.85621
库存:658
