3122-18-1-0500-001-1-TS
    CNC
3122-18-1-0500-001-1-TS 数据手册
service, high temperature appliance etc. P/N 3122-18-1-0500-0XX-1-TS Conductor: (Conductor: TinnedTinned strands)Strands Insulation: Silicone Rubber (Insulation: Silicone Rubber) Fiberglass UL3122 Silicone Rubber Wire 200°C 300V (18AWG) CONSTRUCTION: CERTIFICATION & APPROVALS: Tinned Strands, copper conductor, 34/0.180mm strands. Overall Diameter=2.10+/-0.10mm Insulation Thickness: 0.48mm braid thickness:0.15mm DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: AWG 3122 200°C 300V E108485-S ( )AWG REI HSING CSA SEW-1 200° 300V LL84687 -H- SILICONE RUBBER PHYSICAL & ELECTRICAL PROPERTIES: Rated Temperature: 200℃ ~ -50℃ Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min. Flexibility: Silicone Rubber Insulation Maximum Conductor Resistance: 24.4 ohm/km Resistant to: Oil, hot & cold, lighter, flexing. APPLICATIONS: Pass FT2 flame test Suitable for Lights, Electric heaters, electric heated household service, high temperature appliance etc. PACKAGING: ENVIRONMENTAL APPROVALS: 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 3122-18-1-0500-001-1-TS BLACK 3122-18-1-0500-006-1-TS BROWN 3122-18-1-0500-002-1-TS 3122-18-1-0500-003-1-TS WHITE YELLOW 3122-18-1-0500-007-1-TS GREEN 3122-18-1-0500-008-1-TS ORANGE 3122-18-1-0500-004-1-TS RED 3122-18-1-0500-010-1-TS VIOLET 3122-18-1-0500-005-1-TS BLUE 3122-18-1-0500-011-1-TS GREEN + YELLOW
3122-18-1-0500-001-1-TS 价格&库存
很抱歉,暂时无法提供与“3122-18-1-0500-001-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 500+3.58022500+0.46316
  • 1000+3.405151000+0.44051
  • 1500+3.306001500+0.42768
  • 2500+3.184542500+0.41197
  • 3500+3.106523500+0.40188
  • 5000+3.025505000+0.39140
库存:2429
  • 1+10.353981+1.33945
  • 5+9.243865+1.19584
  • 10+8.8072910+1.13936
  • 25+8.2592725+1.06847
  • 50+7.8649750+1.01746
  • 100+7.48635100+0.96848
库存:2429
  • 1+210.014891+27.16864
  • 2+200.029172+25.87683
  • 3+194.341613+25.14106
  • 5+187.409075+24.24423
库存:4
