21458-26-2-0500-0102-1-TS
    CNC
    MPPE FLT RBB BL/WH 2C 26AWG 100'
21458-26-2-0500-0102-1-TS 数据手册
P/N21458-26-2-0500-0XX-1-TS Conductor: Tinned Strands Insulation: MPPE UL21458 MPPE Wire 80°C 300V (26AWG) CONSTRUCTION: CERTIFICATION & APPROVALS: PHYSICAL & ELECTRICAL PROPERTIES: APPLICATIONS: PACKAGING: ENVIRONMENTAL APPROVALS: Part Number 21458-26-2-0500-0104-1-TS 21458-26-2-0500-0102-1-TS 21458-26-2-0500-0402-1-TS Tinned Strands, copper conductor, 7/0.160mm strands. No. of Conductor: 2 Overall Diameter=1.24*2.47 Insulation Thickness: 0.38mm DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: AWG 21458 ( ) AWG 80°C 300V E108485-S REI HSING VW-1 ROHS REACH Passes UL VW-1 & CSA FT1 Vertical Flame Test. Rated Temperature: -10°C--80°C Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min. Flexibility: MPPE Insulation Maximum Conductor Resistance: 152 ohm/km Resistant to: Oil, hot & cold, lighter, flexing. MPPE Wire, Halogen Free and pass VW-1 flame test, insulation lighter, properties better, no irradiation. Suitable for internal wires of electronic & electrical equipment. 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. Jacket Color Black, Red Black, White Red, White
物料型号:P/N21458-26-2-0500-0XX-1-TS
器件简介:该文档描述了一种符合RoHS标准的MPPE电线,具有锡镀铜导体和MPPE绝缘体,适用于电子和电气设备的内部布线。
引脚分配:文档中没有提供引脚分配信息。
参数特性: - 导体:锡镀铜线,7/0.160mm线径。 - 绝缘厚度:0.38mm。 - 整体直径:1.24mm(单线)和2.47mm(双线)。 - 最大导体电阻:152欧姆/公里。 - 耐油、耐热冷、耐轻量、耐弯曲。
功能详解:MPPE电线无卤素,通过了VW-1火焰测试,绝缘体轻质,性能优越,无辐射。
应用信息:适用于电子和电气设备的内部布线。
封装信息:每卷500英尺。
环境认证:符合2011/65/EC指令,符合所有现行的RoHS指令,可应要求提供当前SGS报告。
颜色选项: - 黑色、红色:21458-26-2-0500-0104-1-TS - 黑色、白色:21458-26-2-0500-0102-1-TS - 红色、白色:21458-26-2-0500-0402-1-TS
21458-26-2-0500-0102-1-TS 价格&库存
很抱歉,暂时无法提供与“21458-26-2-0500-0102-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+104.545171+13.58591
  • 1+172.518361+22.41920
  • 1+996.498421+129.49752
  • 2+948.268392+123.22990
  • 3+920.991283+119.68517
  • 5+887.562445+115.34101
  • 7+866.105477+112.55262
  • 10+843.8274910+109.65754
库存:10
