09456000332
09456000332
    HARTING(浩亭)
09456000332 数据手册
09 45 600 01X0 HARTING PROFINET Type A Cable 4-wire Cat. 5 PVC PROFINET Type A Cable 4-wire, Cat. 5, PVC Advantages General • S  uitable for PROFINET cabling Category 5 / Class D according to ISO/IEC 11 801 ­respectively EN 50 173-1 and ISO/IEC 24 702 respectively EN 50 173-3 This data cable is suitable for PROFINET cabling according to type A in industrial premises and areas. It is useable for fix installation. The core is fitted with 4 wires twisted to quad that allows the transmission of Fast Ethernet 10/100Mbit/s. • Capable for fix installation • Applicable for industrial premises It is designed for fast assembling with the easystripping tool and can be assembled with all HARTING 4-pole RJ45 connectors. • RoHS conform, UL listed, flame retardant Identification Part number Drawing PROFINET Type A Cable 4-wire, Cat. 5, PVC 20 m 50 m 100 m 500 m ring ring ring reel 09 45 600 0130 09 45 600 0140 09 45 600 0100 09 45 600 0110 • • • •  ire: Solid bare copper AWG 22/1 W Insulation: PE Ø 1.5 mm Inner sheath: Polyvinylchloride (PVC) Overall screen: Aluminate foil overlapped, tinned copper wire braid, braid coverage about 90% • Outer sheath: Polyvinylchloride (PVC), flame ­retardant Color code: wh, ye, bu, or Color of inner sheath: white Color of outer sheath: green, RAL 6018 Overall diameter: 6.3 mm – 6.7 mm All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. 09 45 600 01X0 HARTING PROFINET Type A Cable 4-wire Cat. 5 PVC Technical Characteristics Performance  ategory 5 according to EN 50 288-2-1:2003, C IEC 61 156-5:2002 Mechanical Characteristics Minimal bending radius Repeated bending: 7,5 x diameter Single bending: 3 x diameter Tensile strength max. 150 N Electrical Characteristics at 20 °C Transfer impedance 10 MHz 10 mOhm/m Conductor resistance max. 115 Ohm/km Insulation resistance min. 500 MOhm*km Velocity of propagation 5.3 ns/m Characteristic impedance at 100 MHz 100 Ohm ± 5 Ohm Test voltage (wire/wire/screen rms 50 Hz 1min) 2000 V Chemical Characteristics Flame retardant IEC 60 332-1-2 Free of hazardous substances RoHS 2002/95/EG Limited oil resistance Sunlight resistant UL 1581 Sec. 1200 Thermal Characteristics Permissible temperature range fixed operation – 40 °C to + 75 °C flexible operation – 20 °C to + 60 °C Printing  ARTING INDUSTRIAL ETHERNET STANDARD CABLE H CAT 5 PLUS * 22AWG (SHIELDED) (UL) E333432 VERIFIED CAT 5E CMG 75°C or PLTC or AWM 21694 600V FT4 SUN RES * 094560001000100 "Metermarkierung" * "Jahr/ Auftragsnummer" "HARTING-LOGO" Weight about 66 kg/km All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. 09 45 600 01X0 HARTING PROFINET Type A Cable 4-wire Cat. 5 PVC Technical Characteristics   Frequency MHz Attenuation dB/100m NEXT dB typ. Cat 5 max* typ. Cat 5 min* 1 1.6 2.1 80 65.3 4 3.2 4.0 75 56.3 10 5.2 6.3 70 50.3 16 6.9 8.0 65 47.2 20 7.8 9.0 63 45.8 31.25 10.5 11.4 60 42.9 62.5 15 16.5 55 38.4 100 19.5 21.3 50 35.3 * EN 50 288-2-1:2003 All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type B Cable 4-wire Cat. 5 PVC 09 45 600 01X2 PROFINET Type B Cable 4-wire, Cat. 5, PVC Advantages General • S  uitable for PROFINET cabling Category 5 / Class D according to ISO/IEC 11 801 ­respectively EN 50 173-1 and ISO/IEC 24 702 respectively EN 50 173-3 This data cable is suitable for PROFINET cabling according to type B in industrial premises and areas. It is useable for flexible cords. The core is fitted with 4 wires twisted to quad that allows the transmission of Fast Ethernet 10/100Mbit/s. • Capable flexible cords • Applicable for industrial premises It is designed for fast assembling with the easystripping tool and can be assembled with all HARTING 4-pole RJ45 connectors. • RoHS conform, UL listed, flame retardant Identification Part number Drawing PROFINET Type B Cable 4-wire, Cat. 5, PVC 20 m 50 m 100 m 500 m ring ring ring reel 09 45 600 0132 09 45 600 0142 09 45 600 0102 09 45 600 0112 • • • •  ire: Stranded tinned copper AWG 22/7 W Insulation: : PE Ø 1.56 mm (± 0.03) Inner sheath: Polyvinylchloride (PVC) Overall screen: aluminate foil overlapped, tinned copper wire braid, braid coverage about 85 % • Outer sheath: Polyvinylchloride (PVC), flame ­retardant Color code: wh, ye, bu, or Color of inner sheath: white Color of outer sheath: green, RAL 6018 Overall diameter: 6.3 mm – 6.7 mm All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type B Cable 4-wire Cat. 5 PVC Technical Characteristics 09 45 600 01X2 Performance  ategory 5 according to EN 50 288-2-1:2003, C IEC 61 156-5:2002 Mechanical Characteristics Minimal bending radius Repeated bending: 5 x diameter Single bending: 3 x diameter Torsional strength ±180° on 1 m, 30,000 cycles Electrical Characteristics at 20 °C Transfer impedance 10 MHz 20 mOhm/m Conductor resistance max. 120 Ohm/km Insulation resistance min. 500 MOhm*km Velocity of propagation 5.3 ns/m Characteristic impedance at 100 MHz 100 Ohm ± 5 Ohm Test voltage (wire/wire/screen rms 50 Hz 1min) 2000 V Chemical Characteristics Flame retardant UL 1685 (CSA FT 4) Free of hazardous substances RoHS 2002/95/EG Sunlight resistant UL 1581 Sec. 1200 Thermal Characteristics Permissible temperature range fixed operation – 40 °C to + 70 °C flexible operation – 20 °C to + 60 °C Printing  ARTING INDUSTRIAL ETHERNET STRANDED ­CABLE H CAT 5 PLUS * 22AWG (SHIELDED) (UL) E333432 CMG or PLTC or AWM 21695 80°C 600V FT4 SUN RES * 094560001020200 "Metermarkierung" * "Jahr/ Auftragsnummer" HARTING-LOGO" Weight about 68 kg/km All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type B Cable 4-wire Cat. 5 PVC Technical Characteristics 09 45 600 01X2   Frequency MHz Attenuatin dB/100m NEXT dB typ. Cat 5 max* typ. Cat 5 min* 1 2.1 2.1 80 80 4 4 4 76 76 10 6.3 6.3 70 70 16 8 8 65 65 20 9 9 63 63 31.25 11.4 11.4 60 60 62.5 16.5 16.5 55 55 100 21.3 21.3 50 50 * EN 50 288-2-1:2003 All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type B Outdoor Cable 4-wire Cat. 5 PVC 09 45 600 01X5 PROFINET Type B Outdoor cable 4-wire, Cat. 5, PVC Advantages General • S  uitable for PROFINET cabling Category 5 / Class D according to ISO/IEC 11 801 ­respectively EN 50 173-1 and ISO/IEC 24 702 respectively EN 50 173-3 This data cable is suitable for PROFINET cabling according to type B in industrial premises and areas. It is useable for flexible cords. The core is fitted with 4 wires twisted to quad that allows the transmission of Fast Ethernet 10/100 Mbit/s. • Capable for outdoor installation • Applicable for industrial premises It is designed for fast assembling with the easystripping tool and can be assembled with all HARTING 4-pole RJ45 connectors. • RoHS conform, UL listed, flame retardant l Identification Part number Drawing PROFINET Type B Outdoor Cable 4-wire, Cat. 5, PVC 20 m 50 m 100 m 500 m ring ring ring reel 09 45 600 0135 09 45 600 0145 09 45 600 0105 09 45 600 0115 • • • •  ire: Stranded tinned copper AWG 22/7 W Insulation: : PE Ø 1.56 mm (± 0.03) Inner sheath: Polyvinylchloride (PVC) Overall screen: aluminate foil overlapped, tinned copper wire braid, braid coverage about 85 % • Outer sheath: Polyvinylchloride (PVC), flame retardant Color code: wh, ye, bu, or Color of inner sheath: white Color of outer sheath: black, RAL 9005 Overall diameter: 6.3 mm – 6.7 mm All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type B Outdoor Cable 4-wire Cat. 5 PVC Technical Characteristics Performance  ategory 5 according to EN 50 288-2-1:2003, C IEC 61 156-5:2002 09 45 600 01X5 Mechanical Characteristics Minimal bending radius Repeated bending: 5 x diameter Single bending: 3 x diameter Torsional strength ± 180° on 1 m, 30,000 cycles Electrical Characteristics at 20 °C Transfer impedance 10 MHz 20 mOhm/m Conductor resistance max. 120 Ohm/km Insulation resistance min. 500 MOhm*km Velocity of propagation 5.3 ns/m Characteristic impedance at 100 MHz 100 Ohm ± 5 Ohm Test voltage (wire/wire/screen rms 50 Hz 1min) 2000 V Chemical Characteristics Flame retardant UL 1685 (CSA FT 4) Free of hazardous substances RoHS 2002/95/EG Sunlight resistant UL 1581 Sec.1200 Thermal Characteristics Permissible temperature range fixed operation – 40 °C to + 70 °C flexible operation – 20 °C to + 60 °C Printing  ARTING INDUSTRIAL ETHERNET STRANDED CABLE H CAT 5 PLUS * UV protected * 22AWG (SHIELDED) (UL) E333432 CMG or PLTC or AWM 21695 80°C 600V FT4 SUN RES * 094560001020300 "Metermarkierung" * ­"Jahr/ Auftragsnummer" "HARTING-LOGO" Weight about 68 kg/km All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type B Outdoor Cable 4-wire Cat. 5 PVC Technical Characteristics 09 45 600 01X5   Frequency MHz Attenuatin dB/100m NEXT dB typ. Cat 5 max* typ. Cat 5 min* 1 2.1 2.1 80 80 4 4 4 76 76 10 6.3 6.3 70 70 16 8 8 65 65 20 9 9 63 63 31.25 11.4 11.4 60 60 62.5 16.5 16.5 55 55 100 21.3 21.3 50 50 * EN 50 288-2-1:2003 All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type B Cable 4-wire Cat. 5 PUR PROFINET Type B Cable 4-wire, Cat. 5, PUR Advantages General • S  uitable for PROFINET cabling Category 5 / Class D according to ISO/IEC 11 801 ­respectively EN 50 173-1 and ISO/IEC 24 702 respectively EN 50 173-3 This data cable is suitable for PROFINET cabling according to type B in industrial premises and areas. It is useable for flexible cords. The core is fitted with 4 wires twisted to quad that allows the transmission of Fast Ethernet 10/100Mbit/s. • Capable for flexible cords 09 45 600 01X9 • Applicable for industrial premises It is designed for fast assembling with the easystripping tool and can be assembled with all HARTING 4-pole RJ45 connectors. • RoHS conform, flame retardant, halogen free Identification Part number Drawing PROFINET Type B Cable 4-wire, Cat. 5, PUR 20 m 50 m 100 m 500 m ring ring ring reel 09 45 600 0139 09 45 600 0149 09 45 600 0109 09 45 600 0119 • • • •  ire: Stranded tinned copper AWG 22/7 W Insulation: : PE Ø 1.56 mm (± 0.03) Inner sheath: Thermoplastic Copolymer (FRNC) Overall screen: aluminate foil overlapped, tinned copper wire braid, braid coverage about 85 % • Outer sheath: Polyurethane (PUR), flame ­retardant, halogen free Color code: wh, ye, bu, or Color of inner sheath: white Color of outer sheath: green, RAL 6018 Overall diameter: 6.3 mm – 6.7 mm All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type B Cable 4-wire Cat. 5 PUR Technical Characteristics Performance  ategory 5 according to EN 50 288-2-1:2003, C IEC 61 156-5:2002 Mechanical Characteristics Minimal bending radius Repeated bending: 7 x diameter Single bending: 3 x diameter Torsional strength ±180° on 1 m, 30,000 cycles 09 45 600 01X9 Electrical Characteristics at 20 °C Transfer impedance 10 MHz 20 mOhm/m Conductor resistance max. 120 Ohm/km Insulation resistance min. 500 MOhm*km Velocity of propagation 5.3 ns/m Characteristic impedance at 100 MHz 100 Ohm ± 5 Ohm Test voltage (wire/wire/screen rms 50 Hz 1min) 2000 V Chemical Characteristics Flame retardant IEC 60 332-1-2 Free of hazardous substances RoHS 2002/95/EG Thermal Characteristics Permissible temperature range fixed operation – 40 °C to + 70 °C flexible operation – 20 °C to + 60 °C Printing  ARTING INDUSTRIAL ETHERNET STRANDED H ­CABLE CAT 5 PLUS PUR FRNC * 22AWG (SHIELDED) * 094560001020400 "sequential length in meters" * "year/internal order number" HARTING LOGO" Weight about 62 kg/km All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type B Cable 4-wire Cat. 5 PUR Technical Characteristics 09 45 600 01X9   Frequency MHz Attenuatin dB/100m NEXT dB typ. Cat 5 max* typ. Cat 5 min* 1 2.1 2.1 80 80 4 4 4 76 76 10 6.3 6.3 70 70 16 8 8 65 65 20 9 9 63 63 31.25 11.4 11.4 60 60 62.5 16.5 16.5 55 55 100 21.3 21.3 50 50 * EN 50 288-2-1:2003 All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type C Cable 4-wire Cat. 5 PUR PROFINET Type C Cable 4-wire, Cat. 5, PUR Advantages General • S  uitable for PROFINET cabling Category 5 / Class D according to ISO/IEC 11 801 ­respectively EN 50 173-1 and ISO/IEC 24 702 respectively EN 50 173-3 This data cable is suitable for PROFINET cabling according to type C in industrial premises and areas. It is useable for flexible cords especially for drag-chain. The core is fitted with 4 wires twisted to quad that allows the transmission of Fast Ethernet 10/100 Mbit/s. • Capable for drag-line • Applicable for industrial premises It is designed for fast assembling with the easystripping tool and can be assembled with all HARTING 4-pole RJ45 connectors. 09 45 600 01X1 • R  oHS conform, UL listed, flame retardant, halogen free l Identification Part number Drawing PROFINET Type C Cable 4-wire, Cat. 5, PUR 20 m 50 m 100 m 500 m ring ring ring reel 09 45 600 0131 09 45 600 0141 09 45 600 0101 09 45 600 0111 • • • •  ire: Stranded tinned copper AWG 22/7 W Insulation: : PE Ø 1.56 mm (± 0.03) Inner sheath: Thermoplastic copolymer (FRNC) Overall screen: aluminate foil overlapped, tinned copper wire braid, braid coverage about 85 % • Outer sheath: Polyurethane (PUR), flame retardant Color code: wh, ye, bu, or Color of inner sheath: white Color of outer sheath: green, RAL 6018 Overall diameter: 6.3 mm – 6.7 mm All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type C Cable 4-wire Cat. 5 PUR Technical Characteristics Performance  ategory 5 according to EN 50 288-2-1:2003, C IEC 61 156-5:2002 Mechanical Characteristics Minimal bending radius Repeated bending: 7 x diameter Single bending: 3 x diameter Tensile strength max. 150 N Trailing strength 3 million bending cycles bending diameter 200 mm at a speed of 4 m/s acceleration 4 m/s² Torsional strength ± 180° on 1 m, 30,000 cycles 09 45 600 01X1 Electrical Characteristics at 20 °C Transfer impedance 10 MHz Conductor resistance Insulation resistance Velocity of propagation Characteristic impedance at 100 MHz Test voltage (wire/wire/screen rms 50 Hz 1min) Chemical Characteristics Flame retardant Free of hazardous substances Oil resistance UV-resistant Thermal Characteristics Permissible temperature range fixed operation flexible operation 20 mOhm/m max. 120 Ohm/km min. 500 MOhm*km 5.3 ns/m 100 Ohm ± 5 Ohm 2000 V IEC 60 332-1-2 RoHS 2002/95/EG EN 60811-2-1 – 40 °C to + 70 °C – 20 °C to + 60 °C Printing  ARTING INDUSTRIAL ETHERNET TRAILING H ­CABLE CAT 5 PLUS * E333432 ­VERIFIED (UL) CAT 5E PATCH CABLE CMX 75°C FRNC * 2x2xAWG22/7*094560001010100 "Metermarkierung" * "HARTING-LOGO" Weight about 61 kg/km All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type C Cable 4-wire Cat. 5 PUR Technical Characteristics   Frequency MHz Attenuatin dB/100m NEXT dB typ. Cat 5 max* typ. Cat 5 min* 1 2.1 2.1 80 65.3 4 4 4 76 56.3 10 6.3 6.3 70 50.3 16 8 8 65 47.2 20 9 9 63 45.8 31.25 11.4 11.4 60 42.9 62.5 16.5 16.5 55 38.4 100 21.3 21.3 50 35.3 09 45 600 01X1 * EN 50 288-2-1:2003 All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type C Torsional Stress Cable 4-wire, Cat. 5, PUR PROFINET Type C Torsional Cable 4-wire, Cat. 5, PUR Advantages General • S  uitable for PROFINET cabling Category 5 / Class D according to ISO/IEC 11 801 respectively EN 50 173 and ISO/IEC 24 702 respectively EN 50 173-3 This data cable is suitable for PROFINET cabling according to type C torsional stress in industrial premises and areas. It is usable for flexible cords especially e.g. for industrial robot application. The core is fitted with 4 wires twisted to quad that allows the transmission of Fast Ethernet 10/100Mbit/s. • Applicable for industrial premises • Applicable for torsional stress Can be assembled with all HARTING 4-pole RJ45 connectors. • R  oHS conform, UL recognized, flame retardant, halogen free 09 45 600 11X0 l Identification Part number Drawing PROFINET Type C Torsional Cable 4-wire, Cat. 5, PUR 20 m 50 m 100 m 500 m ring ring reel reel 09 45 600 1110 09 45 600 1120 09 45 600 1130 09 45 600 1140 • Wire: Stranded tinned copper AWG 22/19 • Foamed: PE Ø 1.52 mm (± 0.03) • Plastic Tape, overlapped • O  verall screen: tinned copper wire braid, braid coverage about 85 % • O  uter sheath: Polyurethane (PUR), flame retardant Color code: wh, ye, bu, or Color of outer sheath: green, RAL 6018 Overall diameter: 6.3 mm – 6.7 mm All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type C Torsional Stress Cable 4-wire, Cat. 5, PUR Technical Characteristics Performance  ategory 5 according to EN 50 288-2-2:2003, C IEC 61 156-6:2002 Mechanical Characteristics Minimal bending radius  ingle bending: 5 x diameter S max. 150 N Torsional strength ± 180° on 1 m, 1 Mil. cycles Electrical Characteristics at 20 °C Conductor resistance max. 120 Ohm/km Insulation resistance min. 500 MOhm * km Velocity of propagation 4.7 ns/m Characteristic impedance at 100 MHz 100 Ohm ± 15 Ohm Test voltage (wire/wire/screen rms 50 Hz 1 min) 700 V Chemical Characteristics Halogen free 09 45 600 11X0 Flame retardant UL-Style 21 161 (80 °C) IEC 60 332-1-2 Thermal Characteristics Permissible temperature range – 40 °C to + 80 °C Printing  ARTING INDUSTRIAL ETHERNET TORSIONAL STRESS H AWM STYLE CABLE CAT 5 PLUS * 22AWG * E 333435 21161 80°C * 094560001010300 „sequential length in ­meters“ * „year/internal order number“ „HARTINGLOGO“ Weight about 54 kg/km All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Type C Torsional Stress Cable 4-wire, Cat. 5, PUR Technical Characteristics, Transmission performance 09 45 600 11X0   All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Hybrid Cable 4-wire + 4 x 1.5 Cat. 5 FRNC PROFINET Hybrid Cable 4-wire + 4 x 1.5, Cat. 5, FRNC Advantages General • S  uitable for PROFINET cabling Category 5 / Class D according to ISO/IEC 11 801 ­respectively EN 50 173-1 and ISO/IEC 24 702 respectively EN 50 173-3 This data cable is suitable for PROFINET Hybrid cabling according to type B in industrial premises and areas. It is useable for flexible cords and installation also. The core is fitted with 4 data wires twisted to star quad that allows the transmission of Fast Ethernet 10/100 Mbit/s and 4 power wires each of 1.5 mm² cross section. • Capable for flexible cords • Applicable for industrial premises • R  oHS conform, UL recognized, flame ­retardant FRNC It is designed for fast assembling in benefit for the customer. The PROFINET Hybrid cable is best capable for termination with Han® 3 A RJ45 ­Hybrid connector set. l Identification Part number Drawing PROFINET Hybrid Cable 4-wire + 4 x 1.5, Cat. 5, FRNC 10 m 20 m 50 m 100 m 500 m ring ring ring reel reel 09 45 600 0310 09 45 600 0330 09 45 600 0340 09 45 600 0300 09 45 600 0320 Quad • Wire: Stranded tinned copper AWG 22/7 • Insulation: PE Ø 1.55 mm • Color: wh, ye, bu, og • Screen: Aluminate foil overlapped, tinned copper wire braid, braid coverage about 85 % 09 45 600 03X0 Power • Wire: Stranded bare copper 4 x 1.5 mm² 84 x 0.15 mm (AWG 16) • Insulation: FRNC Ø 2.4 mm • Color: bk, number printed Core • Plastic tape overlapped • Outer sheath: Thermoplastic Copolymer (FRNC), flame retardant Color of outer sheath: green, RAL 6018 Overall diameter: 9.7 mm – 10.3 mm All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Hybrid Cable 4-wire + 4 x 1.5 Cat. 5 FRNC Technical Characteristics Performance  ategory 5 according to EN 50 288-2-1:2003, C IEC 61 156-5:2002 Mechanical Characteristics Minimal bending radius Tensile strength 09 45 600 03X0 Electrical Characteristics at 20 °C Quad Transfer impedance at 1 MHz Transfer impedance at 10 - 100 MHz Conductor resistance Insulation resistance Velocity of propagation Characteristic impedance at 100 MHz Test voltage (wire/wire/screen rms 50 Hz 1 min) Operating voltage Repeated bending: 10 x diameter Single bending: 5 x diameter max. 200 N 50 mOhm/m 10 mOhm/m max. 120 Ohm/km min. 500 MOhm x km 5.3 ns/m 100 Ohm ± 5 Ohm 1500 V 150 V Power Conductor resistance Insulation resistance Test voltage (wire/wire/screen rms 50 Hz 1 min) Operating voltage 1500 V 150 V Chemical Characteristics Flame retardant Free of hazardous substances Halogen free IEC 60 332-1-2 RoHS 2002/95/EG EN 60811-2-1 Thermal Characteristics Permissible temperature range fixed operation flexible operation – 20 °C to + 80 °C – 20 °C to + 80 °C max. 14 Ohm/km min. 20 MOhm*km Printing  ARTING PROFINET HYBRID CABLE CAT 5 FRNC * H 4xAWG22/7 + 4x1.5 (SHIELDED) E333435 AWM 21282 * 09456000300200 “internal lot number” ­“sequential length in meters” Weight about 154 kg/km All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING PROFINET Hybrid Cable 4-wire + 4 x 1.5 Cat. 5 FRNC Technical Characteristics   Frequency MHz Attenuation dB/100 m NEXT dB PS NEXT dB EL FEXT dB PS EL FEXT dB Return Loss dB typ. Cat 5 max* typ. Cat 5 min* typ. Cat 5 min* typ. Cat 5 min* typ. Cat 5 min* typ. Cat 5 min* 1 2.1 2.1 65.3 65.3 62.3 62.3 63.8 63.8 60.8 60.8 - - 4 4 4 56.3 56.3 53.3 53.3 51.8 51.8 48.8 48.8 23.0 23 10 6.3 6.3 50.3 50.3 47.3 47.3 43.8 43.8 40.8 40.8 25 25 16 8 8 47.2 47.2 44.2 44.2 39.7 39.7 36.7 36.7 25 25 20 9 9 45.8 45.8 42.8 42.8 37.8 37.8 34.8 34.8 25 25 31.25 11.4 11.4 42.9 42.9 39.9 39.9 33.9 33.9 30.9 30.9 23.6 23.6 62.5 16.5 16.5 38.4 38.4 35.4 35.4 27.9 27.9 24.9 24.9 21.5 21.5 100 21.3 21.3 35.3 35.3 32.3 32.3 23.8 23.8 20.8 20.8 20.1 20.1 09 45 600 03X0 * EN 50 288-2-1:2003 All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING Hybrid Cable 8-wire + 4 x 1.5 Cat. 6 PUR Hybrid Cable 8-wire + 4 x 1.5 Cat. 6 PUR Advantages General • S  uitable for cabling Category 6 / Class E according to ISO/IEC 11 801 respectively EN 50 173-1 and ISO/IEC 24 702 respectively EN 50 173-3 This data cable is suitable for Hybrid cabling in industrial premises as well as outdoor areas. The four twisted pairs PIMF construction is designed for Gigabit Ethernet and gives good EMC capabilities. The cable comes with four power wires which each of them has a 1.5 mm² cross section. Polyurethane is used for the cable sheath which protects the cable against ingress and impact. HARTING offers field assembling Han® 3 A RJ45 Hybrid connectors with reliable IDC termination technology. The connectors are designed for fast and easy assembling without any special tooling. • V  alid for Gigabit Ethernet 1000 Base-T acc. to IEEE 802.3 • C  apable for industrial communications cabling for the outdoor • Very robust and high flexible PUR jacket • Halogen-free and Oil retardant • Good EMC characteristics l Identification Part number Drawing Hybrid Cable 8-wire + 4 x 1.5, Cat. 6, PUR 20 m 50 m 100 m ring ring reel other length on request 09 45 600 0332 09 45 600 0342 09 45 600 0302 Data wires • Wire: Stranded tinned copper AWG 28/7 • Insulation: foamed PE Ø 0.98 mm • Wires: Twisted Pair acc. TIA/EIA 568 • Shielding: F/FTP, tinned copper wire braid coverage about 60 % Power wires • Wire: Stranded bare copper 4 x 1.5 mm² 84 x 0.15 mm (AWG 16) • Insulation: FRNC Ø 2.4 mm • Color: bk, number printed 09 45 600 03X2 Core • Plastic tape overlapped • Outer sheath: Polyurethane, flame retardant and halogen free Color of outer sheath: black, RAL 9004 Overall diameter: 10.0 mm – 10.6 mm All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING Hybrid Cable 8-wire + 4 x 1.5 Cat. 6 PUR Technical Characteristics Performance Category 6 according to EN 50 288-5-2, IEC 61 156-5 Note: Standardized up to 60 m. For length above attenuation is max. 10 % higher. Mechanical Characteristics Minimal bending radius Tensile strength Electrical Characteristics at 20 °C Data wires Conductor resistance Insulation resistance Velocity of propagation Characteristic impedance at 100 MHz Test voltage (wire/wire/screen rms 50 Hz 1 min) Operating voltage Power Conductor resistance Insulation resistance Test voltage (wire/wire/screen rms 50 Hz 1 min) Operating voltage Chemical Characteristics Flame retardant Free of hazardous substances Halogen free Oil resistant UV resistant 09 45 600 03X2 Thermal Characteristics Permissible temperature range fixed operation flexible operation Repeated bending: 10 x diameter Single bending: 5 x diameter max. 200 N 385 Ohm/km 1.5 TOhm x km 4.6 ns/m 105 Ohm ± 5 Ohm 700 V 100 V max. 14 Ohm/km min. 20 MOhm*km 1500 V 150 V UL style 21 523 (80 °C / 30 V) RoHS 2002/95/EG EN 60811-2-1 – 20 °C to + 80 °C – 20 °C to + 80 °C Printing  ARTING HYBRID Ethernet OUTDOOR CABLE CAT 6 H PUR 4x2xAWG28/7 + 4x1.5 094560007000000 * E333435 AWM21523 80°C 30V * "sequential length in meters" "internal lot number" "HARTING-Logo" Weight about 135 kg/km All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING Hybrid Cable 8-wire + 4 x 1.5 Cat. 6 PUR Technical Characteristics   Frequency MHz Attenuation dB/100 m NEXT dB PS NEXT dB EL FEXT dB PS EL FEXT dB typ. Cat 6 max* typ. Cat 6 min* typ. Cat 6 min* typ. Cat 6 min* typ. Cat 6 min* typ. Cat 6 min* 1  3  3.1 75 66 75 64 80 66 80 64 24 20 4  5.6  5.8 80 65.3 80 63.3 80 58 80 55 27 23 10   8.7  9.0 95 59.3 90 57.3 75 50 70 47 29 25 16 11 11.4 95 56.2 90 54.2 70 45.9 68 43 29 25 20 12.2 12.8 91 54.8 88 52.8 68 44 65 41 29 25 31,25 15.3 16.1 88 51.9 86 49.9 62 40.1 62 37.1 30 23.6 62,5 22 23.2 83 47.4 78 45.3 45 34.1 45 31.1 30 21.53 100 28.3 29.9 77 44.3 75 42.3 38 30 40 27 30 20.1 155 36 38.0 72 41.4 70 39.4 38 26.2 38 23.2 26 18.8 200 41.5 43.7 68 39.8 67 37.8 37 24 37 21 23 18 250 47.1 49.5 65 38.3 65 36.3 35 22 35 19 22 17.32 * EN 50 288-2-1:2003 09 45 600 03X2 Return Loss dB All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING Tools Identification Part number HARTING RJ Industrial® Stripping Tool Stripping tool for Ethernet cables including blade cassette 09 45 800 0000 Spare blade cassette 09 45 800 0001 The RJ Industrial Stripping Tool is ready to remove insulation from cables for fast mounting with diameters from 2.5 to 8 mm quick and easy. It allows to remove cable sheath and shielding braid in one. Ha-VIS preLink® Tool Identification HARTING Assembly tool for Ha-VIS preLink® terminale module Part number 20 82 000 9901 The preLink® tool for termination of data cables by cutting all wires in length at the same time. Just to use in combination with the preLink® termination block.
09456000332 价格&库存
很抱歉,暂时无法提供与“09456000332”相匹配的价格&库存,您可以联系我们找货
