N222-01K-BK
N222-01K-BK
    TRIPPLITE
    N222-01K-BK
N222-01K-BK 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Solid Core UTP PVC Bulk Ethernet Cable, Black, 1000 ft. (304.8 m), TAA MODEL NUMBER: N222-01K-BK Highlights ● Less impedance and structural return loss than 100 MHz wire ● Rated for 550 MHz/1 Gbps communications ● High-quality 23 AWG 4-pair solid copper wire ● CMR-rated PVC jacket ● Meets IEEE 802.3ab and ANSI/EIA/TIA 568 standards Package Includes ● Premium high-speed cabling designed for Cat6 premise (in-wall) applications, such as the distribution of data, voice and digital video across Gigabit Ethernet networks. Features Perfect Solution for High-Speed Cat6 Premise Applications ● Designed for distributing data, voice and digital video across Gigabit Ethernet networks ● Delivers speeds up to 550 MHz/1 Gbps ● Reduces impedance and structural return loss compared to standard 100 MHz wire ● Ideal for 10/100/1000 Base-T Ethernet, 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice, EIA/TIA and Token Ring Type 3 applications Premium Construction for Superior Performance ● Made from 23 AWG copper wire ● 4-pair solid UTP ● Minimum near-end crosstalk ● CMR-rated PVC jacket ● Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6, draft 11) TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332196620 1/3 N222-01K-BK Cat6 Gigabit Bulk Solid-Core PVC Cable, Black, 1000 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology Cat6 PHYSICAL Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating CMR Cable Shielding UTP Cable Outer Diameter (OD) 6.2 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 23 AWG Cable Length (ft.) 1000 Cable Length (m) 304.88 Cable Length (in.) 12000 Cable Length (cm) 30480 Shipping Dimensions (hwd / in.) 13.78 x 14.17 x 13.78 Shipping Dimensions (hwd / cm) 35.00 x 35.99 x 35.00 Shipping Weight (lbs.) 29.50 Shipping Weight (kg) 13.38 ENVIRONMENTAL Operating Temperature Range -4° to 167°F (-20° to 75°C) Storage Temperature Range 32° to 140°F (0° to 60°C) COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab CONNECTIONS Side A - Connector 1 BARE WIRE Side B - Connector 1 BARE WIRE Crossover Wiring No Connector Type Bare Wire Angled Connector No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector No STANDARDS & COMPLIANCE Product Compliance RoHS; IEEE 802.3ab 1000Base-T; REACH; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N222-01K-BK 价格&库存
很抱歉,暂时无法提供与“N222-01K-BK”相匹配的价格&库存,您可以联系我们找货
