N222-01K-BL
N222-01K-BL
    TRIPPLITE
    N222-01K-BL
N222-01K-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Solid Core UTP PVC Bulk Ethernet Cable, Blue, 1000 ft. (304.8 m), TAA MODEL NUMBER: N222-01K-BL Highlights ● Meets category 6 cabling standards ● Drastically reduce impedance and structural return loss compared to standard 100Mhz wire ● 4pr Solid - CMR PVC Jacket System Requirements ● For 1000 Base-T (1Gbps Ethernet), 10/100 Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring TYPE 3 applications as well as EIA/TIA applications Package Includes ● Features ● Designed for premise (in-wall) cabling applications ● Meets category 6 cabling standards ● Premium cabling for category 6, category 5e and category 5 applications ● Drastically reduce impedance and structural return loss compared to standard 100MHz wire ● High-quality copper wire ● Length: 1000-ft. Color: Blue Reel-in-a-Box ● 23 AWG, 4-pair solid cable with PVC ( CMR ) jacket ● Deliver stable performance up to 550MHz/ 1 Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6 draft 11) Specifications OVERVIEW UPC Code 037332123077 Technology Cat6 PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CMR Cable Shielding UTP 1/3 1000Ft Cat6 Gigabit Bulk Solid Blue PVC Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Outer Diameter (OD) 6.2 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 23 AWG Cable Length (ft.) 1000 Cable Length (m) 304.88 Cable Length (in.) 12000 Cable Length (cm) 30480 Shipping Dimensions (hwd / in.) 13.78 x 14.70 x 13.78 Shipping Dimensions (hwd / cm) 35.00 x 37.34 x 35.00 Shipping Weight (lbs.) 29.75 Shipping Weight (kg) 13.49 ENVIRONMENTAL Operating Temperature Range -4° to 167°F (-20° to 75°C) Storage Temperature Range 32° to 140°F (0° to 60°C) COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab CONNECTIONS Side A - Connector 1 BARE WIRE Side B - Connector 1 BARE WIRE Crossover Wiring No Connector Type Bare Wire Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector No IP20 Rated No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; IEEE 802.3ab 1000Base-T; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N222-01K-BL
1. 物料型号: - 型号编号:N222-01K-BL - 技术规格:Cat6(六类)
2. 器件简介: - 该产品为六类千兆固体芯UTP PVC大卷以太网电缆,蓝色,长度为1000英尺(304.8米),符合TAA(贸易协定法案)。
3. 引脚分配: - 两端均为裸线(BARE WIRE),不支持交叉线序(Crossover Wiring),连接器类型为裸线(Bare Wire),没有直角连接器(Angled Connector)。
4. 参数特性: - 符合六类布线标准,与标准100MHz线相比,大幅降低阻抗和结构回波损耗。 - 使用高品质铜线,长度为1000英尺,颜色为蓝色,采用卷轴包装。 - 23 AWG,4对固体线,PVC(CMR)护套。 - 提供高达550MHz/1Gbps的稳定性能。 - 符合当前大多数行业标准,包括IEEE 802.3ab、IEEE 802.5、ANSI/EIA/TIA 568、ISO/IEC 11801和ETL(六类草案11)。
5. 功能详解: - 专为室内(墙体内)布线应用设计,适用于六类、超五类和五类应用。 - 提供高达550MHz/1Gbps的稳定通信性能。
6. 应用信息: - 适用于1000 Base-T(1Gbps以太网)、10/100 Base-T(以太网)、100 Mbps TPDDI、155 Mbps ATM、ISDN、语音和令牌环3型应用以及EIA/TIA应用。
7. 封装信息: - 包装包括1000英尺Cat6千兆大卷固体蓝色PVC电缆。 - UPC代码:037332123077。
N222-01K-BL 价格&库存
很抱歉,暂时无法提供与“N222-01K-BL”相匹配的价格&库存,您可以联系我们找货
